![]() | Home > Puma (Tdci) > 2 Stroke oil in diesel. |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
I am only a newbie here but have lurked in the background for too long. I am certain this has been discussed many times before. Personally I have added two stroke in a ratio of somewhere between 40ml-50ml ( its never an exact science for me on a garage forcourt with two stroke bottle markings that defy my eyesight) per 10 litres of fuel, from about 500 miles. I have to say, its quieter, runs smoother, slightly better mpg and I have no hessitation in using cheap supermarket fuel.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4785 ![]() ![]() |
There have been lots of thoughts on the above on this site. Just put it into the SEARCH facility and lose yourself for a week. 1982 88" 2.25 diesel
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Glug glug glug yum ! More vegetable juice vicar ?
And then we'll have a nice chat about Noisekiller and Waxoyl and tyres and engine oil ![]() Yes Toplink thats a pretty famous thread and like all the best ones it ends up in a big bitchy arguement I think. But IMHO 2 stroke is the business for keeping all your internals clean. I never fill up without it ![]() |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 822 ![]() ![]() ![]() |
Rossy what qualities of 2 stroke per tank you using
![]() Nidge |
The general recommended quantity is 1:200 to the diesel.
But when I fill up I just order a bottle and put it in, it's 200ml and by the time I fill up the truck takes in about 45L. For the 2.4, Jaso-FB spec is fine, but on the 2.2 only Jaso-FC spec should be used due to the DPF. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
![]() I generally put a drop of two stroke in on refill as it seems to make the engine run just that bit smoother. Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Nidge I use either Carplan (from B&Q) or Tesco motorcycle 2SO which are both exactly the same product from the same manufacturer just different labels. They are Jaso FB spec and are about € 7 for a litre bottle. I use 50ml per 10 litres of diesel. The only thing I have to be careful about here is the quality of diesel available as one of our local independants was caught selling the washed stuff so its Topaz, Texaco or Apple green filling stations for me even though they all use a variety of suppliers but at least its Kosher fuel. |
Thanks Rossy will try some in the tank of my "new " 200 tdi, might quiten it down a bit .... What did you say ..!!!!
![]() N. |
Think you might need FC spec. for the Puma owing to the catalytic converter. FB will be o.k. for the 200 tdi. And yes the 2 stroke will make the 200 tdi a little quieter. Used it in our now retired 200 tdi and it had a noticable effect noisewise. Took the edge off the noise and gave very good emissions results at the NCT. 1982 88" 2.25 diesel
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
The big question is are there any disadvantages to this practice on a puma engine. Its never over in my land rover.
2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
This question has been asked before with no definitive answer. The only proviso with adding the 2 stroke is a more frequent oil change regeime i.e. 6000 miles instead of 12000 miles.So long as it does no harm and if we are just wasting our time and money then no harm done. I have been using it steadily for sometime now and like I said before, I cannot prove that it is benefial but the Puma is very quiet. I cannot claim an increase in mpg as 29.** is as good as I get. As I noted in an earlier post the 1992 200 tdi sailed through the MOT with it's lowest emissions ever after regular doses of 2 stroke in the diesel. Have not taken the EGR out from the Puma to check how clean it is but one of the purported benefits of using 2stroke is that it keeps the EGR clean. Rossy has great faith in it from experience with use of it in an earlier car.Seems the Puma needs the more expensive FC spec 2 stroke owing to the fact that it is fitted with a catalytic converter. Seems the FB spec. 2 stroke could clog it up.Anyway there at least two sides to this debate,plus those sitting on the fence. A truck driver did tell me that his truck,very modern and highly sophisticated, was designed to burn engine oil with the diesel. He did not know the technicalities but that is how it was. Taking this as a yardstick it will hardly do our engines any harm in the doses we use. I put 5 litres of 2 stroke (Castrol Actevo which is FC spec)into every 1000 litres of diesel when I fill the tank in the yard. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
FC is a must for the 2.2 or any engine with a DPF. I once asked my engineer buddy about FB and CATs and he reckons a simple 2 stage cat as is in the Puma will be unaffected by the slightly higher ash content in FB as it could in theory deal with a litre or more dirty engine oil being burned every 1k miles easily and that produces much more muck than 2SO which burns extremely cleanly. I'm going to be the guinea pig on this one I suppose !
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 ![]() ![]() ![]() |
[quote="spudfan"]
The only time I have ever tried 2so the EGR went tits up and needed to be replaced. There has been quite a debate about 2so here in South Africa. No-one has come up with any scientific evidence that it is good for your engine - it's a more seat of the pants gut-feel reaction. Not for me, thanks. |
[quote="robharvey"]
Interesting to hear of this bad reaction linked to adding 2stroke. Would'nt it be lovely to get a definitive answer either way. Any further details "rob" as to the time frame you used the 2stroke and the EGR going bad?Any info that helps with this debate is always welcome. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
