Home > Td5 > Oil leak suggestions
rallysteve
Losing the will to live with this Defender, have replaced the engine due to melted piston, new engine runs okay but hideous oil leak. Changed alternator as the vacuum pump was leaking badly. However looked this morning and i still have a substantial oil leak on the front right corner of the engine.
There isnt much there to leak really. Fairly sure its not the vac pump feed or drain. Only other thought is the timing chain tensioner. Its definetly the front corner, dripping off the bottom of the alternator mounting.
Any suggestions at all please?
Cheers 02' 110 TD5 Double Cab Rebuild Thread
Post #1023407 3rd Feb 2024 11:03am
1NRO
Bolt for the tensioner maybe?
Post #1023478 3rd Feb 2024 7:32pm
excossack
Oil feed/return pipe for the alternator?
Cam end seal? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1023624 5th Feb 2024 9:34am
rallysteve
Got chance to investigate again yesterday afternoon, top of the new alternator and vac pump is nice and clean, no signs of leakage around the tensioner or oil feed. However, the blanking plug on the front of the cam sprocket was hanging out Shocked
Have swapped it out for another one I have which looked to have a better o-ring. Hopefully that will solve the issue now. It was certainly not an issue when i changed the alternator the other weekend.
Cheers,
Post #1023625 5th Feb 2024 9:47am
excossack
I think the front cam seal never seals. They always seem to leak even with sealant. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1023631 5th Feb 2024 10:28am
balmybaldwin
United Kingdom 2002 Defender 90 Td5 CSW Buckingham Blue
Twinwoods do an upgraded O ring for the front camshaft cover
Post #1069208 6th Jun 2025 7:01pm
excossack
https://twinwoods4x4.co.uk/product/replace...-oil-seal/
I think you refer to ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069212 6th Jun 2025 7:30pm
balmybaldwin
Yes thats the one. Can't attest to how long it lasts as it's only been in about 3 weeks, but its a significantly snugger fit
Post #1069215 6th Jun 2025 8:34pm
