Home > Td5 > 10P or 15P ECU? |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 132 |
The cutover from 10P to 15P engine numbers is very clean for UK vehicles, happening around mid August 2001 builds.
With 4 previous owners, there could be all sorts of history that wasn't passed on. I was always unearthing things on the Defender's i've owned! Does the ECU have a sticker on it with the correct VIN? This is how they came from the factory. If you can show some photos of the head, someone with more knowledge might be able to spot any differences. It may have only had a replacement ECU and injectors? LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
28th Jan 2024 12:54am |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 73 |
Hi Will@LRW
When you say mid August 2001, do you mean the calendar year or registration period? Mine was built 7th August 2000 as a 2001 model. I think you refer to the calendar year so they'd likely be 2002 models? The only sticker on the ECU is the one shown below. I've removed the lid to check inside as I am dealing with the common oil in the loom issue. I'll get some photo's of the head at some point. Thanks. Click image to enlarge Click image to enlarge |
28th Jan 2024 12:33pm |
Jabberwocky Member Since: 27 Oct 2021 Location: Luxembourg Posts: 197 |
I thought 10p engines had a MSB part number and 15p had NNN? I have a MY2000 defender with a 10p engine, however the ECU has been changed at some point, it is dated 2003 and has the NNN model number on it.
28th Jan 2024 5:24pm |
@Jabberwocky, you could be in the same situation as I think I may be in - Not that it's problem, in fact a good thing.
So far as I understand it, at 10P engine compared to 15P: - Same bottom end - Different head - Different injectors - Different ECU 10P ECU has soldered in CPU chip whereas 15P ECU is updatable via OMDB. https://www.instagram.com/roxi_defender90/ |
28th Jan 2024 8:23pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6494 |
NNN flashable ECUs can be used on a 10P, but not the other way around (MSBxxxxxx non flashable on 15P) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
28th Jan 2024 8:52pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1572 |
Different rockers too |
28th Jan 2024 8:56pm |
Ahhh. Very useful to know. Thanks https://www.instagram.com/roxi_defender90/ |
28th Jan 2024 9:03pm |
I'll add rockers to my notes. Cheers https://www.instagram.com/roxi_defender90/ |
28th Jan 2024 9:04pm |
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 |
MSB ecu’s were discontinued and superceeded by the NNN ecu. Theres a correct flashable 10p map file to suit the NNN. Chances are the originals failed at some point and been replaced with a NNN ecu. If you’ve got access to a nanocom would be worth checking to see what vin number is stored in the ecu if no sticker on the top.
28th Jan 2024 10:12pm |
August 2001 build date, which is the changeover from 2001 to 2002 models. 15P vehicles started being registered in Aug/Sep/Oct 2001 but there were still 10p vehicles being registered at that time. LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
29th Jan 2024 8:52pm |
Thanks Will@LRW and LWB97, I think the most likely scenario is the first ECU became toast and the backwards compatible NNN ECU was fitted with a 10P map.
I've learnt a lot from this thread. Thanks to all those who contributed. https://www.instagram.com/roxi_defender90/ |
29th Jan 2024 8:57pm |
