![]() | Home > Puma (Tdci) > HELP! No drive, no gears, grinding sound |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18049
Agree. If a vehicle has a history of eating shafts, I think the Ashcroft shaft is the only choice since it is the only solution which allows for a small amount of flex. Similarly the LOF clamping force is a concern, however I haven't heard of any problems arising from its use. As noted above, the engineering of the IRB shaft appeals but only if you have sound reason to think that you don't have misalignment.
Here, unusually, I find myself unable to agree! Nothing, not a single aspect, of the conversion to the Ford engine, suggests competent engineering to me, It only just manages adequate engineering. It suggests to me that the process of replacing engineers with stylists was well underway, and I have speculated that the job was left to the work experience team. Ironically once the enthusiastic owner, aided by very competent aftermarket component suppliers, has reworked the vehicle at considerable expense and corrected the inherent defects, I think that the 2.4 Defender is undoubtedly the best classic Land-Rover of recent times. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3652
I elaborate... why would an 'engineer' design another point of failure, and what to me seems a rather expensive solution? I can only assume that they needed to fulfill the MT82 mainshaft bolt torque requirement of 180Nm, as that holds the gearbox together (preload), so they needed to have access to the bolt while still having some 'flexibility'. A design like the IRB concept is easier and surely cheaper to manufacture! Or perhaps they had tunnel vision and they only could see splines? The additional splines probably gave that additional misalignment compensation- perhaps on paper was a good design - but possibly FoMoCo, the manufacturer of the adaptor housing did not bother to keep to the specified tolerances, and possibly one of the explanations to the wide range of life time out of the original adaptor shaft. As with everything, there will be (I hope) a normal distribution. Some adaptor housings just happened to be on the nominal dimensions. Those went to the lucky ones But the above is just speculation. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Although it's nearly 25 years since I was involved in production engineering, I really doubt that it is an expensive solution. Bearing in mind the sources of cost involved, design (negligible), material, machining, and assembly, I think the splined coupling is the cheapest solution in a medium-volume production environment.
The design task is trivial since both ends are already defined by the gearbox and transfer box interfaces and the spline size can be picked from a table of transmitted power. I reckon there's a couple of man-hours max in the design. Re. materials, I don't think there is a two-part design which would use less material. When machining losses are taken into account, there will be more material machined away from the IRB part than the JLR part. The machining operations may be simpler for the JLR part since the manufacture of splines is a standard process, the IRB part whilst not complex does require a second precision machined face plus the drive dowels a precision positioned and fit. Probably not a huge difference in machining time and cost, I think. I suspect the biggest difference is in assembly time and skill. It undoubtedly will take longer to assemble the IRB shaft and require a greater degree of skill, and but bearing in mind how badly some of the splined joints have been assembled it may be that the extra time for a bolted coupling would have been a good investment. I do however, upon reflection, think that the work experience lad or lass who designed this intended that it should be assembled with lubricant, and I wonder at what point someone took the decision to omit the lube. Simply greasing thoroughly with a moly-based grease may well have reduced the failure rate significantly. |
| All times are GMT |
