![]() | Home > Puma (Tdci) > HELP! No drive, no gears, grinding sound |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3652
Sounds like the classic adaptor shaft that has worn.
Many threads on that topic. The good news is that there are good aftermarket solutions. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| Learningasigo Member Since: 30 Nov 2023 Location: Midlands Posts: 28
Thanks Will that stop it going into hi and low? And also the continuous grinding sound and no movement in gears
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1371
If you never used the hi-lo it can bind up. Even had that on the P38 I just bought which has an electric shift motor. Its not the internals that are the problem (plenty of lubrication) its the linkage outside the box.
The shaft that commonly fails connects the output of the gearbox to the input of the transfer box. It wears dt alignment issues and lack of lubrication. Possible the noise you heard earlier is it slipping a tooth and now it has just failed completely? As was said do a search it is very well documented. Last edited by TexasRover on 26th Jan 2024 10:11am. Edited 1 time in total |
Thanks. I suspected as much and the garage said that would prob be the case. Never ever used it neither did the previous owner.
I wonder if it’s a good idea to exercise the diff weekly to stop it ceasing? Is it an easy fix? Adapter shaft and output shaft - these are two different things? The Hanes book doesn’t help me work out this. |
Yes, freeing up and lubing the linkage then regular use. I occasionally slip it on low for maneuvering as it kinda easier. On the P38 its an automatic so you have to remember to brake twice as hard
I am not 100% familiar with the later MT82 6 speed gearbox, but I understand there is an intermediate shaft that connects the standard MT82 outputshaft to the LT320 tranfer case input. This is the shaft that wears.
Its kinda ironic they have this issue as earlier on (1980) they had the same issue connecting the LT77 (or Chrysler 3 speed auto) to the same transfercase, which was resolved, but had the exact same symptoms. I faced this issue myself for two cars and it looks like a bit of a stupid design mistake. Anyhow too much info. The problem you likely have is well documented and can be fixed but it is a transfer case out solution, so will cost a bit of shoptime, |
| Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537
If it is the output shaft TUD500020/LR030054 combo which sounds likely it can be replaced with gearbox and transfer box in situ so not too bad a job.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6059
Probably too late but if you are stuck and need help give me a shout. I’m about an hour south of PBog so could drive up take a look, or get you to somewhere safe.
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18049
It is most likely to be the usual output adaptor shaft failure, a very well-known and very common problem as all regulars on this forum will know (and discussed in many threads). It is however just possible that a gear in the transfer box has broken up, but that is a very rare failure so not likely. The hi/lo/difflock mechanism is renowned for seizing up if not used, so again the likely explanation is that that is a non-related issue.
If the adaptor shaft has failed it is well worth fitting one of the improved solutions such as the one from Ashcroft Transmissions (other solutions are now available).
No it can't, the transfer box must come out. |
Good man! It is qualities like this among the forum members that sets this forum above all others. |
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21033
Definitely is.
Whilst it does sound like adaptor shaft as mentioned, the hi low mech does get completely dry and seized up. I do use it when I can and diff lock every few months for that very reason, but when I took the linkage off mine last it was completely dry and no lube there until I greased it nicely. The gearstick mechanism is often the same, they often never get lubed after factory assembly unless the owner goes out of their way to do so. And it does make a lot of difference. ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you everyone. This forum really is the best. Honestly I was so amazed that within 2 mins of breaking down, and only just making it across the A1 😱, that two defender owners stopped (neither in a defender I may add!) and towed me to work.
Now with the garage and will update but assume it is the linkage. Plenty of forum posts and will look at the uprated options. Seem to be two options LOF and Ashcroft so a bit of research required. Having said that this one has managed to last 78k so not too bad considering the number of posts. I did twitch a little when we took it out of low and high to fault find and hope it just required a bit of lube. Although the mechanic suggested often these need a little motion and can often be sorted by moving forward and trying again…. Not overly impressed by Nene who never called back at all. It’s not the first time they haven’t but I know they are busy…. |
Mines still on the genuine Adaptor shaft, I’m aware of the issue and always had it checked and lubed on the good advice by Blackwolf previously.
Last time it was looked at, it was still in perfect condition. Unfortunately, some people have bad luck with alignment and fretting on them often caused by being dry and non lubed out of the factory. There may be some possibility it’s a clutch spring that’s jammed up and came out though, and that can have sporadic effects of seeming like the clutch is fine one minute but not another. It does sound like adaptor shaft failure though, and if so then a new clutch going in and Slave would be a a good idea. You can have the high / low slip out of drive and go neural, but there shouldn’t be any noises. It would just seem like being in neutral gears, silent but no drive. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I have been advised to do the clutch and slave at the same time by another garage but loathed to do this as it was replaced 16th of May last year and only done 7k miles since.
The current quote, if it is the transfer box input shaft, is £890. If I start adding things on it’s going to get v expensive v quickly! |
| All times are GMT |
