Home > Puma (Tdci) > 2.4 wont start in cold temperatures
jf_est
Estonia 2007 Defender 90 Puma 2.4 SW Java Black
First up, apologies if this is addressed elsewhere, but couldn't seem to find an answer via search.
I'm having issues getting my engine started in cold weather (2.4). By cold, I'm talking -15 to -20. The car is parked in a covered garage complex, so probably shielded from the worst of it but its still pretty chilly in there.
I've tried cycling the glow plugs, as sometimes after 2/3 cycles it will fire up. At the moment, now we're closer to -20 here in Estonia, it's refusing entirely to fire.
Research suggests checking voltage to glow plugs, or replacing the glow plugs entirely. Keen to understand whether anyone else has run into the issue and has any advice.
Post #1020293 6th Jan 2024 10:58am
Kev the Rev
United Kingdom 2007 Defender 90 Puma 2.4 HT Keswick Green
When you said "cold" I thought you meant the engine had cooled down. I think -20 is more than "cold"
I don't think my car would even turn over at that temperature.
What point does diesel freeze? I guess they must put stuff in the diesel there to stop it freezing
Hope you get it sorted
Post #1020294 6th Jan 2024 11:12am
jf_est
Hah! Yes, I should have clarified in the title perhaps.
I think the fuel does begin to gel around -10, so that could also be an issue. There's anti-gel solutions you can buy at the local auto parts store, but I'm not sure how keen I am on chucking a load of additive into the tank if its not the issue.
Post #1020295 6th Jan 2024 11:20am
andy63
Never experienced those sort of temp, but from the reading I've done it is important that your fuel is suitable for those temp and wax free..
Assuming you are free of water in the system is there any way you can pre heat or warm the filter as that's going to be your weak point in terms of blockage..
Post #1020301 6th Jan 2024 1:10pm
nicolas0505
France
hello
I don't know the diesel fitrability limit in your country, in France we have -15 for normal diesel and premiums -21. The fuel filter should already be drained to see if there is any water, we also recommend keeping the tank as full as possible to avoid condensation inside.
Post #1020303 6th Jan 2024 1:48pm
jf_est
Thanks for the advice. We're set for some much milder weather in the coming days so I'll see if I can check the filter for water, and fill up with some arctic diesel at the local gas station. They tend to stock it from December onwards.
Post #1020304 6th Jan 2024 1:57pm
markb110
In those areas that have those cold temperatures could you not get a block heater?
I used to see them all the time when visiting Minneapolis.
Post #1020316 6th Jan 2024 6:43pm
jf_est
I have thought about a block heater, but I'm not confident where I'd get one. Might reach out to the local parts specialist to see if they can advise on one. I've got power to my parking space, so it should be feasible to plug an electric one in if I can get one for the car.
Post #1020317 6th Jan 2024 6:46pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Some race cars use a small heater/pump to warm up the block before cranking they are electric and normally powered by an external battery. It’s really just a pump and heater element maybe if you can wire in one of them? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1020319 6th Jan 2024 7:08pm
If you are looking for a block heater then Amazon USA probably may have something, they are good for international but not cheap and should deliver to your country?
Also, if you can only get standard diesel, try running permanently with a trusted brand of fuel additive such as Millers diesel additive, which will have a higher Cetane rating and also should help prevent the diesel thickening so much at really cold temperatures. (And help prevent sludge and diesel bug etc).
You might want to get it plugged in and see if the glow plugs are showing any faults.
I realise, that depending on where you are supply may be an issue, but some of these things may help to prevent further issues in future.
Also, keep an eye on the battery voltage and what it’s sitting at, at rest.
It shouldn’t be lower than 12.6v and definitely not lower than 12.2v to start in temperatures as low as that.
Possibly a portable jump start pack maybe of use, that you can charge up indoors and take out.
Which will give you that extra CCA and voltage boost. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1020329 6th Jan 2024 9:21pm
jf_est
Really appreciate that advice. I think I'll start with a conditioner for the battery, just to ensure it's looked after when the temperatures really drop. I've got a terminal point just under the hood so should be easy to keep connected.
Fortunately, theres a lot of auto parts stores near me with all sorts of additive choices. I'll try adding some additive, and topping off the tank with arctic diesel tomorrow. Once the milder weather comes next week I'll try giving it a good run.
Amazon is a bit hit a miss here, we usually have to order from Germany, but thankfully it seems the big agri-industry here has a lot of block heater options for tractors. I'll have to look at whether any of these would be suitable for the Defender.
Thanks for the suggestions!
Post #1020330 6th Jan 2024 9:28pm
There are heaters that plumb into the coolant lines and preheat the engine, either diesel fuelled or electric, and to cope with temps like that I'd be inclined to fit one. I also have a distant memory (and I'm going back more than ten years) of a discussion on this forum of an LR mod for the 2.4 to address ultra-cold starting, something like an electric heater in one of the breather lines or similar. When I get the time I'll hunt for the thread.
Post #1020332 6th Jan 2024 9:28pm
jf_est
Ah thank you! Curious to see what that thread suggests.
I think plumbing something in on the coolant lines sounds like a solid approach! Thanks for the suggestion.
Post #1020333 6th Jan 2024 9:31pm
Blackwolf - Was that a Webasto system? Rings a bell to me, but wasn’t something I was following at the time, so I don’t know much about it. _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1020335 6th Jan 2024 9:34pm
Webasto is one of the makers of diesel-fuelled heaters, and a Webasto preheated was an option on the TD5 Disco 2. I know that there are folk who've fitted D2 heaters to Defenders. There are Chinesium versions available which supposedly are acceptable too.
Might be worth searching the forum for "webasto".
Post #1020337 6th Jan 2024 9:39pm
