![]() | Home > Puma (Tdci) > 2.4 wont start in cold temperatures |
Kev the Rev Member Since: 04 Jun 2023 Location: Ripon Posts: 51 ![]() ![]() ![]() |
When you said "cold" I thought you meant the engine had cooled down. I think -20 is more than "cold"
I don't think my car would even turn over at that temperature. What point does diesel freeze? I guess they must put stuff in the diesel there to stop it freezing Hope you get it sorted |
jf_est Member Since: 12 Nov 2023 Location: Tallinn Posts: 27 ![]() ![]() ![]() |
Hah! Yes, I should have clarified in the title perhaps.
I think the fuel does begin to gel around -10, so that could also be an issue. There's anti-gel solutions you can buy at the local auto parts store, but I'm not sure how keen I am on chucking a load of additive into the tank if its not the issue. |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 761 ![]() ![]() |
Never experienced those sort of temp, but from the reading I've done it is important that your fuel is suitable for those temp and wax free..
Assuming you are free of water in the system is there any way you can pre heat or warm the filter as that's going to be your weak point in terms of blockage.. |
nicolas0505 Member Since: 23 Dec 2020 Location: briançon Posts: 80 ![]() ![]() |
hello
I don't know the diesel fitrability limit in your country, in France we have -15 for normal diesel and premiums -21. The fuel filter should already be drained to see if there is any water, we also recommend keeping the tank as full as possible to avoid condensation inside. |
Thanks for the advice. We're set for some much milder weather in the coming days so I'll see if I can check the filter for water, and fill up with some arctic diesel at the local gas station. They tend to stock it from December onwards.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2667 ![]() ![]() ![]() |
In those areas that have those cold temperatures could you not get a block heater?
I used to see them all the time when visiting Minneapolis. |
I have thought about a block heater, but I'm not confident where I'd get one. Might reach out to the local parts specialist to see if they can advise on one. I've got power to my parking space, so it should be feasible to plug an electric one in if I can get one for the car.
Race.it Member Since: 27 Aug 2019 Location: Algeciras Posts: 835 ![]() ![]() ![]() |
Some race cars use a small heater/pump to warm up the block before cranking they are electric and normally powered by an external battery. It’s really just a pump and heater element maybe if you can wire in one of them? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20865 ![]() ![]() |
If you are looking for a block heater then Amazon USA probably may have something, they are good for international but not cheap and should deliver to your country?
Also, if you can only get standard diesel, try running permanently with a trusted brand of fuel additive such as Millers diesel additive, which will have a higher Cetane rating and also should help prevent the diesel thickening so much at really cold temperatures. (And help prevent sludge and diesel bug etc). You might want to get it plugged in and see if the glow plugs are showing any faults. I realise, that depending on where you are supply may be an issue, but some of these things may help to prevent further issues in future. Also, keep an eye on the battery voltage and what it’s sitting at, at rest. It shouldn’t be lower than 12.6v and definitely not lower than 12.2v to start in temperatures as low as that. Possibly a portable jump start pack maybe of use, that you can charge up indoors and take out. Which will give you that extra CCA and voltage boost. _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ Last edited by custom90 on 6th Jan 2024 9:32pm. Edited 1 time in total |
Really appreciate that advice. I think I'll start with a conditioner for the battery, just to ensure it's looked after when the temperatures really drop. I've got a terminal point just under the hood so should be easy to keep connected.
Fortunately, theres a lot of auto parts stores near me with all sorts of additive choices. I'll try adding some additive, and topping off the tank with arctic diesel tomorrow. Once the milder weather comes next week I'll try giving it a good run. Amazon is a bit hit a miss here, we usually have to order from Germany, but thankfully it seems the big agri-industry here has a lot of block heater options for tractors. I'll have to look at whether any of these would be suitable for the Defender. Thanks for the suggestions! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17802 ![]() ![]() ![]() |
There are heaters that plumb into the coolant lines and preheat the engine, either diesel fuelled or electric, and to cope with temps like that I'd be inclined to fit one. I also have a distant memory (and I'm going back more than ten years) of a discussion on this forum of an LR mod for the 2.4 to address ultra-cold starting, something like an electric heater in one of the breather lines or similar. When I get the time I'll hunt for the thread.
Ah thank you! Curious to see what that thread suggests.
I think plumbing something in on the coolant lines sounds like a solid approach! Thanks for the suggestion. |
Blackwolf - Was that a Webasto system? Rings a bell to me, but wasn’t something I was following at the time, so I don’t know much about it. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Webasto is one of the makers of diesel-fuelled heaters, and a Webasto preheated was an option on the TD5 Disco 2. I know that there are folk who've fitted D2 heaters to Defenders. There are Chinesium versions available which supposedly are acceptable too.
Might be worth searching the forum for "webasto". |
