Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc
Page 7 of 11 <123 ... 678 91011>
verrilli
United States
This is the cable that I used that worked
https://www.amazon.com/dp/B07Y5FJ695?ref=p...s&th=1
Post #1016066 22nd Nov 2023 8:15pm
DefenderMidlands
Park assist should show a steering wheel symbol with a p in it on the Home Screen. May need pivi rebooting and or locking up for 15 mins
 MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016069 22nd Nov 2023 8:27pm
ckamps
United States
On my 2021 D90 First Edition US, I was able to get ACC (the most important feature to me), ATPC, TR2, and dynamic mode enabled. I also enabled advanced tow assist, but have not yet tried it.
In dynamic mode, I don’t have any red lighting on the instrument cluster and interior lights. The latter is no surprise given that my D90 does not have the ambient lighting feature. No big deal to me. I’m enjoying the heavier steering feel of dynamic mode, but I have not yet noticed the impact of other settings. Presence of the red lighting effect in the instrument cluster seems to be vehicle, year, and/or trim level specific and not related to the programming tool.
Park assist did not work even after following the direct CCF editing approach based on examples shared in the other Gap-oriented threads. I don’t see the icon on the right. I see the grayed out setting in the driver assistance section. When I click on the Park Assist icon, I just see the icon displayed in the middle of the screen. Similar to some other people. Since I had the braking error for a while, I was thinking that it was getting in the way of park assist working similar to the braking error causing ACC to not work. However, even after the braking error was cleared and not present, park assist still did not work (yet ACC did).
As mentioned in those threads, enabling park assist seems to be a hit or miss affair across multiple programming tools. I was interested in giving park assist a go just from a techie perspective. We have it in one our GTIs, but never use it.
Remembering start/stop setting doesn’t seem to have worked for my D90 either. I don’t mind the auto stop feature, but I figured I’d try to enable the memory feature just to have it. Again, I used the direct CCF approach to enable the memory feature. Perhaps it’s working, but I just don’t realize it. Smile 2021 D90 Pangea First Edition
2022 D110 X-Dynamic HSE Eiger Grey
Post #1016103 23rd Nov 2023 2:58am
BD1
United States
Thanks aquascape and everyone else. This is a great alternative to the gap tool if you just want to change a few settings.
On my 2023 90 I got auto start/stop. auto unlock approach/lock away, fog/high beams, and dynamic (with red lights/guages) all to work.
Post #1016108 23rd Nov 2023 4:36am
DefenderMidlands
I think the jet pro is most useful as a diy tool for activating acc, tr2 auto and atpc which can’t yet be done with the gap tool. MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Post #1016116 23rd Nov 2023 7:47am
ckamps
United States
A very helpful step-by-step guide for using JET Pro:
https://landroverforums.com/forum/2020-def...post882806 2021 D90 Pangea First Edition
Post #1016259 24th Nov 2023 3:20pm
tooth_dr
Northern Ireland
Can the trailer reversing mode be activated by the jet tool? I was able to get it partially working by gap but ended up with the usual errors.
Also how likely is it that Pat at gap will get this sorted in the next month or two? Don’t want to spend then find it’s on my gap tool at Christmas 🎄
Post #1016290 24th Nov 2023 9:04pm
ckamps
United States
I used the JET Pro tool to enable advanced tow assist on my 2021 D90 First Edition (US) without any apparent errors, but I had not yet taken the time to test it. (ACC was my top priority).
Spurred on by your post, I hooked up a trailer and gave it a go this evening. It appears to work as expected. Since it was getting dark, I'll need to give a real test during the day tomorrow.
Here's a pic of it in effect. I didn't notice any errors and all of the features as documented seemed to be available. During my brief test this evening, auto steering kicked in as well.
Post #1016306 25th Nov 2023 12:44am
tooth_dr
Northern Ireland
You are a legend sir! Thanks for taking time to check this for me. Once I clear a few evenings I’ll order the software 3 day trial
Post #1016307 25th Nov 2023 12:53am
doncarajo
Australia
Which option is for advanced tow assist? I have a 75th edition 110. I have activated dynamic mode with the red lights etc but I don't see the tow assist script.
Edit: I have followed the options on the sticky for tow assist, changed the values manually. Can't test it but can't see why it wouldn't work.
Post #1016319 25th Nov 2023 9:40am
doncarajo
Australia
So far I have had success with:
Second gen terrain, ATPC, RS, Dynamic i (including red lights everywhere)
Start-Stop memory
Remote control pops open the tailgate
The only other two I am interested in are:
Parking assist
Tow reverse assist
Post #1016330 25th Nov 2023 11:41am
ckamps
United States
I used the JET Pro tool to edit the CCF settings as called out in the following “Gap Diagnostic Tool working Activations” topic:
https://www.defender2.net/forum/topic89347.html
After setting CCF fields properly, just like when using one of JET Pro’s built-in scripts, I used the standard set of steps to write the CCF changes and perform the other actions on the other tabs as called out elsewhere in this topic in which we’re having this discussion. 2021 D90 Pangea First Edition
Post #1016337 25th Nov 2023 1:27pm
doncarajo
Australia
Yes, I worked it out before your reply but thank you for your help.
Post #1016397 25th Nov 2023 10:40pm
verrilli
United States
aquascape wrote:
Possible park assist settings
Activate Park Assist
EUCD-059 Parking Assistance
Standard: Without Parking Assistance
Change to: PDC (Front, Rear) - Parking (Parallel, Exit)
EUCD-099 Park Assist Camera
Standard: Without Park Assist Camera
Change to: With Park Assist Camera
EUCD-140 Pdcautoactivationmenu
Standard: Not supported
Change to: With PDC Auto Activation menu
MultiCAN-469 PDCAutoActivation
Standard: Not Supported
Change to: Default OFF configurable
MultiCAN-500 PDCBtnFCIM
Change to: Fitted
MultiCAN-602 PDC
Standard: PDC not fitted
Change to: 10 Channel fitted ( Park Assist)
MultiCAN-786 Park Assist
Standard: Not Fitted
Change to: Full Auto VarD (Fully automated park assist with automated steering breaking accelaration and gears)
This worked for me. It does the whole process by itself - forward / reverse and steering. Thanks!
Post #1016718 29th Nov 2023 3:25pm
Nelu
Romania
It looks like the price just double up for the software, 199 for 72hrs acess. New Defender D240, Gondwana Stone
Post #1016905 30th Nov 2023 10:03pm
