Home > Technical > What Gauge Steel??
Cubflyer
United Kingdom 1994 Defender 90 300 Tdi SW Arles Blue
What Gauge Steel??
Evening folk ...
I'm considering doing a repair to my 1994 chassis (corrosion)
Can anyone advise on the right gauge/spec of sheet metal I should be looking at please.
Many thanks
John 2010 Defender 90 300Tdi CW (White/1994)
2021 Defender 90 300Tdi SW (Blue/1994)
Post #1015487 17th Nov 2023 9:59pm
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
i have used 2.5mm steel sheet on chassis repairs.always use at least the original thickness of the part you are repairing.
Post #1015532 18th Nov 2023 12:58pm
Cubflyer
Thanks Paul - Appreciate the reply. 2.5mm / 14 AWG is good Thumbs Up
Thanks very much
ATB John 2010 Defender 90 300Tdi CW (White/1994)
Post #1015558 18th Nov 2023 6:22pm
Dinnu
I thought AWG is for Wire.
Pretty sure that the original chassis is just 2mm with a lot of internal spot welded stiffening. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015564 18th Nov 2023 7:29pm
Cubflyer
Hi Dinnu ... I think you'll find SWG is simply the European initials for Standard Wire Gauge and AWG is initials American Wire Gauge.
However, it matters not IMHO ... it a gauge of a thickness, be it wire or sheet metal
ATB
Post #1015567 18th Nov 2023 7:39pm
Dinnu
Thumbs Up
Success in the repair. That even more important Wink 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015569 18th Nov 2023 7:56pm
