Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 28 of 39 <123 ... 272829 ... 373839>
Very Rural
United Kingdom 2012 Defender 110 Puma 2.2 CSW Aintree Green
Good luck, I hope you don't have a replacement chassis, as they won't do the recall if you have!
Post #1015455 17th Nov 2023 6:12pm
ickle
Or bigger wheels / tyres
Or a lift kit
Or a roll cage
Or poly bushes
Or a sump guard
Or furry dice.....(remember those!)
Post #1015457 17th Nov 2023 6:21pm
keith
So I’ll take that as a no then Big Cry
Post #1015459 17th Nov 2023 6:27pm
Re: Should I get a new axle ?
keith wrote:
Crickey 27 pages on this subject Shocked
My recall for the brackets is booked for next week. Yesterday whilst replacing 2 track rod ends I notice lots of axle oil loss from the very weld that we are talking about, on the bottom of axle behind the wheel hub. Cleaned up and sure enough this is that failed weld. Even though out of warranty should this well known fail point be replaced with a new axle considering it’s a recall on a safety item?
I believe that you should but it will be a very interesting test. I'd be inclined to take it (very carefully) to have the recall work carried out to see what happens.
Post #1015464 17th Nov 2023 6:54pm
spudfan
Ireland
I wonder how JLR will react to this. The leak must surely indicate that the weld has failed in that spot. Will they tell you to drive it to a maindealer for assessment? If so they are telling you to drive with the signs of a major safety fail. When you get to the dealer and they see the leak and inform JLR, what will JLR do? Fitting brackets will not stop the leak in the weld. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1015465 17th Nov 2023 7:05pm
keith
Spud…. That’s the very point I’m asking.
So I went into the dealer today and made this very point. “The known failure point has failed, irrespective of brackets being fitted to the part JLR have known to be faulty and dangerous for many years, hence the recall on many vehicles” I was told to bring it in and a workshop diagnosis would be sent to JLR for their decision.
My question is… have there been any axles at all been replaced for the weld failure?
Post #1015468 17th Nov 2023 7:35pm
I may be mistaken but I seem to recall that the original recall (which is reproduced somewhere on this forum) did say that failed axles were to be replaced and unfailed axles were to get the brackets.
The brackets won't stop the welds from failing but should keep you alive if they do, so it would be interesting to hear from anyone who's had the brackets fitted and subsequently experienced weld failure.
Since LR has publicly admitted that the axles may be faulty it is hard to see how they could avoid replacing them, but if any organisation can find a way to wheedle out of it, it will be JLR.
Post #1015470 17th Nov 2023 7:51pm
spudfan
Ireland
So despite the axle exhibiting early warning signs that the weld is failing you have been told to "bring it in." Someone somewhere is not thinking this through. Advising someone to drive a vehicle exhibiting the symptoms of the issue that the magic brackets are supposed to ameliorate does not sound like good advice. If the vehicle went for its MOT tomorrow with the weld leaking oil, how would they approach it? 1982 88" 2.25 diesel
Post #1015473 17th Nov 2023 8:24pm
Harry dog
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
When I drove into my trusted Independent 4x4 garage to report a slight oil leak from somewhere around the NS front axle. After cleaning off the area and examining up on the ramps - I was told in no uncertain terms that I wouldn't be driving the vehicle home!! So how JLR would suggest you drive into one of their service centres to get it checked out is beyond me. They clearly don't really understand what the issue is!
I ended up having the axle casing changed for an older discovery one with proper welding and all been well since (that was 2018). Having now had the recall notice, I'm waiting for my nearest Land Rover dealer to get the brackets into stock. It was booked in a month ago only to be told the day before that didn't have any......It will be interesting to see, when it finally does go in for the brackets if they notice that the axle casing isn't original.
Post #1015488 17th Nov 2023 10:22pm
Dinnu
That is very irresponsible of the dealer to say the least. I would ask them to either send a transporter to take your Defender to them, or a technician visit you where the Defender is located. No way I would be driving it in that condition.
As far as I read, some owners that had weld failures but at the time were outside the recall range got a small discount on an axle case. Now yours having the recall might change the complete game.
Can I ask if it is the nearside weld that failed? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1015497 18th Nov 2023 7:52am
jst
exactly what i was told. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1015509 18th Nov 2023 11:10am
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
It’s interesting that they say there are no brackets available. 5 days ago I ordered both the left and right brackets from Jaguar Landrover Classic Parts, which I believe is part of JLR, and they were dispatched 4 days later. Seems if you’re paying they are available!
Out of interest I did look on YouTube what axle friction welding is. Once you see this it makes identification really simple with the two parallel beads of weld confirming a friction weld on axles. 2010 2.4 TDCI Puma Defender 90
Post #1015518 18th Nov 2023 11:26am
spudfan
Ireland
So where did it all go wrong?
Post #1015545 18th Nov 2023 3:11pm
Very Rural
I'm not often lost for words....
Perhaps I'll let my local Main Dealer comment: (This is printed on the service folder I received the document in, that stated the work had been done, except that it hadn't)
"NO STANDARD HIGHER - NO COMMITTMENT STRONGER"
Beat that!
Post #1015547 18th Nov 2023 4:49pm
ickle
No Standard Higher - this is true, the showrooms are on a par if not better than the rest
No Commitment Stronger - to their shareholders obviously, not plebs with old model cars, we're expendable!
Post #1015556 18th Nov 2023 6:04pm
