![]() | Home > General & Technical (L663) > Activating ACC, ATPC, TR2 Auto, Park Assist, wheel size etc |
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 67 ![]() ![]() ![]() |
They sent me a key and I played with it a little last night. I couldn't get anything to function quite right though.
With the IID tool, I would start the vehicle, plug in the adapter and keep my foot on the brake while updating and it would go through it's series of ignition cycles to load the new ccf. When I tried that with this tool, it went really strange. It shut off the ignition and somehow kept the engine running and then throw a ton of errors to the point I would have to use the IID tool to reset the ccf back to where it was. What process did you go through to get it to update the ccf on your rig? 20MY Defender 110 Fuji White |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 286 ![]() ![]() |
I connected the Enet cable, turned ignition on, clicked on connect in software, then licked on CCF brushing at top menu then 'read CCF', clicked on any off the CCF files I wanted to change (selected the changes at the top in the drop down value list), then clicked 'Write current data' to make the changes (alternatively select one of their scripts from the script list like no 16 that I used called 'PIVI second generation terrain +ATPC+RS+Dynamic I' to add ATPC, Dynamic, TR2 Auto to the car).
If you change a CCF that causes the brake error then click on DTC diagnosis at the top, then select 1416 DADC module, read all DTC, then clear all DTC or click on Vehicle Function in the main menu and allow central configuration to clear error (restart gateway). All works perfectly on mine, only took a few minutes. If you run the backup before you start it creates a .bak file that you can easily restore back to. Hope that helps MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Update on testing. I got it to work without the car running. The key is to have the ignition on, but not running.
I got ACC working on a base model defender using this tool to upload the "PIVI ACC" script they have. I then had the DADC re-learn the ccf with the tool/software and ACC functions showed up on the next ignition cycle. I drove and tested the ACC and it worked as intended. Now, I'm going to work on the automatic parking to see if I can get it up and running without error. I also made some changes with the gap tool to see if it would break the ACC and so far, that hasn't happened. My theory is that once the DADC re-learns and expects ACC to be configured, it maintains that setting. 20MY Defender 110 Fuji White |
EataPeach4923 Member Since: 07 Jun 2023 Location: USA Posts: 17 ![]() ![]() |
Did anyone have to install drivers? It’s telling me “connection failed” whenever I try to connect to my car. Plug in Ethernet > turn on ignition > start took on Windows virtual machine on my MacBook. On top of that, I cannot contact support as the WhatsApp account I made to ask about the thing to begin with has now been disabled to due alleged spam….
I haven’t got a Mac so can’t really comment on that side. Windows didn’t require any drivers to work.WhatsApp Gary at autosvs. He was very helpful. There is also a tech guy James I think on WhatsApp. Number was on the autosvs website under support MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
Try script 16. That should enable atpc, tr2 auto and dynamic mode. I think the key is making the DADC module relearn to clear the errors. Park assist I think will work, autosvs thought it would. MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Everything is seemingly working as it should, but ACC is not activating. I run the script, the car does its thing and restarts, comes back online with all the errors. I select the 1416 read all and clear all, but ACC is not there after this. Do you use the script or manually enable?
Possibly need to restart the gateway / restart all modules. I already had ACC so can’t say for sure on that. Someone else may be able to help you more
![]() Click image to enlarge MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
forzahog Could you advise what you did to make the car relearn the DADC module? MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar
To clear the errors I think you need to DADC central configuration alignment, restart gateway,
It’s a work in progress this but it could be a really useful tool to activate many things on the defenders MY25 D350 Defender 110 X, Carpathian Grey, 7 Seat, Electric Towbar |
Paladino Member Since: 07 Dec 2022 Location: Serbia Posts: 30 ![]() |
Did anyone manage to activate park assist?
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1448 ![]() ![]() ![]() |
Just one thing I was told to only have the ignition on when doing ccf modifications with the IID tool and I know when you use Pathfinder, again you just have the ignition on not the engine running ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
![]() Just think of all the fuel I could have saved. 20MY Defender 110 Fuji White |
I’m not convinced the ACC script works. Shouldn’t it appear even when I get the errors?
