![]() | Home > Puma (Tdci) > Help stuck won’t start. |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1092 ![]() ![]() ![]() |
Are you in a position to unhitch the caravan to try a jump start? Or even better, can you get someone just to pull you with a tow strap to jump start you. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
Rescue01 Member Since: 17 Jul 2015 Location: Aberdeen Posts: 105 ![]() ![]() |
Was going to ask if it would bump start. Had it stall long time ago and I’m sure it wouldn’t start while I was rolling but I’m on a hill so could try?
Definitely give it a go. Just don’t go too far down the hill if it puts you in any worse of a situation.
2nd gear would be my pick. Get a bit of momentum. If it starts then that would point me to your starter motor being at fault. 2017 5.0 V8 Supercharged RRS SVR 2008 2.4 110 Utility Station Wagon XS. |
Thanks. It’s pouring with rain and getting dark.It’s been a crap week already.Will start fresh in the morning in the dry.I’m thinking it’s the Ignition switch.
DT. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2503 ![]() ![]() ![]() |
I would check earth points and lock/unlock with the fob a few times Puma 110" SW
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2522 ![]() ![]() |
try locking and unlocking it a few times to begin with 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS |
Thanks for all the tips.
I suspect the ignition barrel is not turning all the way to the start position. Vehicle and caravan both moved after bump starting it. I’m back at work next week and no time to look at properly so it’s outside my local garage for them to sort. ![]() |
Fantastic news the bump start worked..! 2017 5.0 V8 Supercharged RRS SVR
Just to let you know that it was indeed the ignition barrel that was faulty and wouldn’t turn. All fixed and back to normal.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17990 ![]() ![]() ![]() |
Thank you, it is always good to hear that the problem has resolved and what the diagnosis was. It all helps build up the knowledge base.
