Home > Puma (Tdci) > Help stuck won’t start.
Rescue01
Currently stuck with the caravan on the back. 2011 2.4Tdci
Stalled while manoeuvring the caravan. Tried the key nothing. Rolled to a safe stop.
Ignition lights come on but nothing when I turn the key further to start. Can’t remember if engine warning light comes on with ignition?? Tried disconnecting battery for a bit but still nothing. All other electrics work battery full. Feels funny on that last turn of the key to start. Any ideas??? Will have to try and find someone with a towbar to move the caravan.
Suggestion welcome.
Post #1012014 21st Oct 2023 2:27pm
BrickBox
Are you in a position to unhitch the caravan to try a jump start? Or even better, can you get someone just to pull you with a tow strap to jump start you. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1012015 21st Oct 2023 2:37pm
Rescue01
Was going to ask if it would bump start. Had it stall long time ago and I’m sure it wouldn’t start while I was rolling but I’m on a hill so could try?
Post #1012019 21st Oct 2023 2:42pm
BrickBox
Definitely give it a go. Just don’t go too far down the hill if it puts you in any worse of a situation.
2nd gear would be my pick. Get a bit of momentum. If it starts then that would point me to your starter motor being at fault. 2017 5.0 V8 Supercharged RRS SVR
Post #1012024 21st Oct 2023 3:28pm
Rescue01
Thanks. It’s pouring with rain and getting dark.It’s been a crap week already.Will start fresh in the morning in the dry.I’m thinking it’s the Ignition switch.
DT.
Post #1012027 21st Oct 2023 3:45pm
MK
I would check earth points and lock/unlock with the fob a few times Puma 110" SW
Post #1012096 22nd Oct 2023 11:25am
Welshsurferdude
Wales
try locking and unlocking it a few times to begin with 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1012115 22nd Oct 2023 3:22pm
Rescue01
Thanks for all the tips.
I suspect the ignition barrel is not turning all the way to the start position.
Vehicle and caravan both moved after bump starting it.
I’m back at work next week and no time to look at properly so it’s outside my local garage for them to sort.
Thumbs Up
Post #1012117 22nd Oct 2023 3:27pm
BrickBox
Fantastic news the bump start worked..! 2017 5.0 V8 Supercharged RRS SVR
Post #1012126 22nd Oct 2023 4:59pm
Rescue01
Just to let you know that it was indeed the ignition barrel that was faulty and wouldn’t turn. All fixed and back to normal.
Thumbs Up
Post #1012595 25th Oct 2023 4:53pm
Thank you, it is always good to hear that the problem has resolved and what the diagnosis was. It all helps build up the knowledge base.
Post #1012597 25th Oct 2023 4:58pm
