![]() | Home > Maintenance & Modifications > Rear tub repair panels - advice needed |
| NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1681
You’ll have to drill out the spotwelds on the old one from behind and then bond or rivet the new one on. I’d take the tub off and do it upside down it’ll be a right nightmare otherwise. That’s some bad corrosion on that year for a td5? Cattle Farmer or boats?
| Ap077 Member Since: 19 Sep 2021 Location: York Posts: 24
Replied below
Hi, I'm trying to avoid taking the tub off if I can avoid it, however if I have to then I will. Very bad corrosion yep! It's an 07 Puma. Cattle farmer in Yorkshire was its previous owner Big Cry Thanks! |
The under floor supports are riveted on each side with dome headed steel rivets and the tub to crossmember bracket is the full length one that bolts to the top face. You access the bolts to remove it through the hole on the crossmember underside.
Personally I’d remove the tub it’ll take far longer and far more effort to fix it in place for the sake of a few bolts. This might give you and idea of what it’s like underneath without the supports on. (Be careful if you remove them as I think they’re not all the same height) Click image to enlarge Click image to enlarge Click image to enlarge |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2530
Best to remove tub then you can address everything that needs doing and rub down and paint chassis
having said that its probably easier to get a better used tub and spray to match? 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3650
On a 90, (but I think also a 110 HT), the tub is also prone to corrode at the front corners, where the seat belt brackets are attached to. There are L shaped steel brackets that go from the chassis to the seat belt unit which seem to be installed bare steel by Land Rover. These start to rust in no time, and create a very bad galvanic reaction between the ali and the steel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18045
Looking at the cross member I'd have thought that you would be removing the body to facilitate chassis repairs! The tub looks like the least of your problems.
Nice one thanks! I might have to bite the bullet and remove the tub just so I can turn it upside down and carry out the repairs! Thanks for the pointers |
That might not be a bad option to be fair! I’ve seen used TD5/TDCI tubs for around £500 which isn’t awful really! I’ll look into it thank you! |
Yep! The rear cross member isn’t in the best shape really, I’m going to remove the floor and then see if it’s repairable or whether it should just be replaced |
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
That is precisely what I was thinking. Tub off to expose the hidden gems. Best of luck 👍 |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2417
Get the tub off and be prepared for things to get a whole lot worse. What you can see is always just the tip of the iceberg. Probably best to start researching replacement chassis. Sorry to be a doomsayer but you need to be prepared for what you'll find. I hope you didn't pay too much for it !
Tub off it is! Cross member bolts off, tub sides off (they’re already off) seatbelt brackets off. What else? Thanks team! 👊 |
The chassis is actually okay! The cross member is the worst area to be fair, forward on its just surface rust. I’ve been over it with a fine toothcomb. I’m going to get the tub off and put a cross member on it |
| All times are GMT |
