Home > Maintenance & Modifications > Rear tub repair panels - advice needed
Ap077
Evening,
I've got a corroded rear tub on my defender, my plan is to replace the floor, rear body mounting, thresh & seal, rear light cappings, the rear floor support and the quarter panels themselves.
My question itself is what order to do this in? I understand I'll need the tub floor off, then the rear panels off either side to replace the rear body mount itself.
Is there any tips or tricks to do this? I'm a technician by trade so I'll happily admit bodywork is not my forte!
I've attached some photos of the panels I mean, and the state of mine.
They're the panels I've currently bought (and some stainless rear tub support brackets that go on the corner)
Thanks
Alex
Post #1011163 13th Oct 2023 6:45pm
NickMc
You’ll have to drill out the spotwelds on the old one from behind and then bond or rivet the new one on. I’d take the tub off and do it upside down it’ll be a right nightmare otherwise. That’s some bad corrosion on that year for a td5? Cattle Farmer or boats?
Post #1011174 13th Oct 2023 9:16pm
Ap077
Replied below
Post #1011178 13th Oct 2023 9:27pm
Ap077
Hi,
I'm trying to avoid taking the tub off if I can avoid it, however if I have to then I will.
Very bad corrosion yep! It's an 07 Puma. Cattle farmer in Yorkshire was its previous owner Big Cry
Thanks!
Post #1011179 13th Oct 2023 9:28pm
NickMc
The under floor supports are riveted on each side with dome headed steel rivets and the tub to crossmember bracket is the full length one that bolts to the top face. You access the bolts to remove it through the hole on the crossmember underside.
Personally I’d remove the tub it’ll take far longer and far more effort to fix it in place for the sake of a few bolts.
This might give you and idea of what it’s like underneath without the supports on. (Be careful if you remove them as I think they’re not all the same height)
Post #1011180 13th Oct 2023 9:51pm
Welshsurferdude
Wales
Best to remove tub then you can address everything that needs doing and rub down and paint chassis
Thumbs Up
having said that its probably easier to get a better used tub and spray to match? 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1011182 13th Oct 2023 9:56pm
Dinnu
On a 90, (but I think also a 110 HT), the tub is also prone to corrode at the front corners, where the seat belt brackets are attached to. There are L shaped steel brackets that go from the chassis to the seat belt unit which seem to be installed bare steel by Land Rover. These start to rust in no time, and create a very bad galvanic reaction between the ali and the steel. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1011185 14th Oct 2023 3:10am
Looking at the cross member I'd have thought that you would be removing the body to facilitate chassis repairs! The tub looks like the least of your problems. Shocked
Post #1011189 14th Oct 2023 8:41am
Ap077
Nice one thanks! I might have to bite the bullet and remove the tub just so I can turn it upside down and carry out the repairs! Thanks for the pointers
Post #1011193 14th Oct 2023 10:20am
Ap077
Thumbs Up
That might not be a bad option to be fair! I’ve seen used TD5/TDCI tubs for around £500 which isn’t awful really! I’ll look into it thank you!
Post #1011194 14th Oct 2023 10:20am
Ap077
Yep! The rear cross member isn’t in the best shape really, I’m going to remove the floor and then see if it’s repairable or whether it should just be replaced
Post #1011195 14th Oct 2023 10:21am
Screbble
That is precisely what I was thinking.
Tub off to expose the hidden gems.
Best of luck 👍
Post #1011201 14th Oct 2023 11:48am
Mo Murphy
Get the tub off and be prepared for things to get a whole lot worse. What you can see is always just the tip of the iceberg. Probably best to start researching replacement chassis. Sorry to be a doomsayer but you need to be prepared for what you'll find. I hope you didn't pay too much for it !
50 Shades of Pennine Grey
Post #1011202 14th Oct 2023 12:16pm
Ap077
Best of luck 👍
Tub off it is! Cross member bolts off, tub sides off (they’re already off) seatbelt brackets off. What else? Thanks team! 👊
Post #1011221 14th Oct 2023 5:54pm
Ap077
Mo
The chassis is actually okay! The cross member is the worst area to be fair, forward on its just surface rust. I’ve been over it with a fine toothcomb. I’m going to get the tub off and put a cross member on it
Post #1011222 14th Oct 2023 5:56pm
