Home > Td5 > New nocking sound after diff oil change
Page 2 of 2 <12
Mdm
would drain the oil and see how much metal comes out.
clean thoroughly.
refill fresh oil and see how it goes ,i would hope its ok if you haven't done many miles.
add some magnetic diff plugs as well
Post #1009016 26th Sep 2023 6:19pm
Kozzy
United Kingdom 2001 Defender 110 2.5 TD CSW Caledonian Blue
yeah only done about 200m on it like this at low speed.
Will clean it out and get a replacement cover as well just in case, this is nafff.
What do you guys recommend flushing the diff out with ?
And yes the drain plug is a magnet one, i was surprised it there were no shavings on it at all. Got da 110 TD5 2001 Smile
Post #1009031 26th Sep 2023 7:29pm
Mdm
brake cleaner or similar solvent is all you need.
if the plug doesn't leak when its wound in i wouldn't swap the pan.
200mtr at slow speed and minimal metal loss you should be ok
Post #1009032 26th Sep 2023 7:40pm
Page 2 of 2 <12
