Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 21 of 39 <123 ... 202122 ... 373839>
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
A pointless recall if it doesn’t cover all affected VINs
Mine was a 2009 110 DC when the axle went on the seam, luckily moving relatively slowly when it pulled me straight into a hedge.
I replaced the axle myself as Land Rover weren’t interested.
I now have a 2009 130 DC , obviously outside the recall but more than a little worrying . https://www.instagram.com/hustynminepark/
Post #1008641 24th Sep 2023 8:09am
spudfan
Ireland
Hard to believe the lack of interest from Land Rover when the fault that the magic brackets are supposed to ameliorate actually occured. Cannot have been a pleasant experience. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1008670 24th Sep 2023 11:42am
Bluericky
So once all these brackets are fitted, then what ?
If or should we say when the casing fails, do they then replace the axle or by installing the brackets have they, as far as JLR are concerned done their bit ?
There are certainly more than a few forum members who have installed the brackets themselves over the years. That will no doubt void any future claims . https://www.instagram.com/hustynminepark/
Post #1008671 24th Sep 2023 12:05pm
I haven't heard of anyone whose axle has failed after having the brackets fitted (note that I am not suggesting that the brackets prevent the axle from failing), but I find it very hard indeed to see how Land-Rover could avoid a claim for a new axle since by supplying the brackets they have admitted that there is a problem and in their own recall wording have stated that the bracket do not prevent failure, merely (and perhaps arguably) reduce the severity of the consequences.
Post #1008678 24th Sep 2023 1:15pm
spudfan
Ireland
This is akin to a wiper motor failure and Land Rover giving you a cloth to wipe the windscreen...while you are driving. 1982 88" 2.25 diesel
Post #1008684 24th Sep 2023 1:34pm
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Just checked and my MAR 2012 90 has friction welded axles which is a pleasant surprise.
Post #1008691 24th Sep 2023 3:23pm
spudfan
Ireland
If you did discover a leak in the axle case and you contacted JLR, they would probably tell you to book it into a maindealer for them to examine it. By rights it would need to be collected on a flat bed lorry. Imagine driving it to the dealer and the axle failed and you were involved in an accident with other vehicles. I doubt if your insurance company would look benignly on your claim as they would tell you that you were driving a vehicle with an obvious defect. Yet you were doing as the manufacturer instructed you to have the fault examined. I might be a little naieve here but perhaps Land Rover are planning for axle replacements to be fitted and are using the brackets as a stop gap until the axles are fitted, thus implying that they are actually being pro active. Probably NAIEVE with capital letters .... 1982 88" 2.25 diesel
Post #1008749 24th Sep 2023 11:56pm
Rolling with laughter Oh my, dream on!
Post #1008750 24th Sep 2023 11:59pm
spudfan
Ireland
Maybe I should tell JLR that "I like to be kissed before I get screwed...." 1982 88" 2.25 diesel
Post #1008751 25th Sep 2023 12:14am
Ianh
They have already done the latter, so too late for the former. Very Happy
Post #1008752 25th Sep 2023 1:00am
Dinnu
Indeed a pleasant surprise.
As I do not doubt your skill to differentiate between mig and friction welded axle casing flanges, I find this so strange. My August 2012 is mig welded.
Maybe someone found an axle in their gray stock, and decided to use it. Damn, they should have discovered it 4 months later Whistle
So do you also get the N706 recall? Cool 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008759 25th Sep 2023 8:21am
TexasRover
I would think in a car assembly line you have different suppliers supplying parts purchased in batches and then they get consumed as they come in so you might end up mixing one suppliers friction welded axles with another suppliers MIG welded axle.
Might even be taking place on the axle assembly side of things.
Then it would take some time to figure out that one supplier is not meeting the quality standard and soon you have a right mess up on your hands.
Surely today's solution to that is to have a massive database where every component on every car can be traced back. Having personally seen the Range Rover and then Defender production line I doubt the defender line ever evolved to that level (lot of crates and men in blue coats)
Post #1008760 25th Sep 2023 8:41am
Dinnu
As far as I know, the factory for axles changed late 2009 / early 2010. That is when the switch from friction to mig welded was done as well. If the new factory was under different management or not (competitor to the original manufacturer), I do not know. But surely, mig welding required lower investment at the new factory.
Again, AFAIK, all axle cases were manufactured in the UK. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008765 25th Sep 2023 8:53am
TexasRover
The reference of the axles cases being manufactured in India was based on what an LR engineer had told Payney1000 according to one of the other discussions. Later referred to has a red herring, so yes to avoid confusion I will edit and remove reference.
Post #1008767 25th Sep 2023 9:14am
MartinK
Just got my letter too! Mine is one of the very last of the 2.4's, It's just past it's 12th birthday (i bought it new)
Better get it booked in I guess! Not been to a LR dealer for years! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #1008794 25th Sep 2023 11:39am
