Home > Technical > Ignition barrel |
Big Red the Yorkshire Defender Member Since: 25 Aug 2023 Location: Darlington Posts: 8 |
Hi, I am fitting the attached new ignition barrel, do I need to program the the key to the car in any way, and if so how? Thanks
17th Sep 2023 1:24pm |
What age Defender?
17th Sep 2023 1:34pm |
Yes a 110 Puma, thank you both!
17th Sep 2023 5:06pm |
I completed the work this week, it turned out there was some programming (ish) to accept the key using the key fob.
22nd Sep 2023 3:35pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
The ignition switch/barrel is definitely not an item which requires programming, so you've had to have that done for some other reason. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
22nd Sep 2023 3:48pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 1796 |
I bet that other reason was the fob needed a resync, ie. with doors shut press fob lock button four times in quick succession then unlock button once.
Which would have been nothing to do with the barrel being replaced. |
22nd Sep 2023 4:17pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4507 |
My 2008had an ignition barrel change and no programming was required. 1982 88" 2.25 diesel
23rd Sep 2023 12:16am |
