Home > Puma (Tdci) > 2015 Defender 110 Headlight Issue |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6510 |
Your steering angle sensor is probably now out of calibration if you didn't place it back exactly in the same place as it came off. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Aug 2023 2:45pm |
I don't think it self learns (some cars you can steer full left to right and back again etc), it's a diagnostic tool job. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
31st Aug 2023 2:51pm |
Daysleepers Member Since: 15 Dec 2022 Location: Suffolk Posts: 110 |
Not sure why it’s staying on now, but that’s the traction control light.
31st Aug 2023 6:26pm |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 |
I read on another forum that you have to drive over 5m oh to reset it. No idea if it’s right or not, but worth a try.
31st Aug 2023 6:56pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 909 |
No that is the DSC (Dynamic Stability Control) ETC (traction control) on the defender is a different light and to get on my soapbox lessor motor manufacturers use the aforementioned light as a traction control light. As they simply have Gaslit the public into thinking that when directional control is lost that means traction and that means taking throttle control away from you to regain it. My works transit does the same, spins a wheel (in a straight line) and that stupid light comes on and the ECU backs the throttle off. Coming back on topic As martin says it's more than likely that you have disturbed the SAS you will have to get it plugged in to do a relearn. Essentially it's lost how far left or right input you have steered. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
31st Aug 2023 7:51pm |
