![]() | Home > In Car Electronics > Power routing battery seatbox to drivers seatbox? |
| kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317
I took battery positive to the drivers seatbox under the carpet and across the top of the transmission tunnel.
Took the negative from under the car where the factory installed positive is routed. |
| pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76
I did install two flexible metal conduits between the two boxes and routed some of the wires through them. They do come with screw ends. I prefer them compared to simple rubber grommets as you can't get the later really waterproof. The metal conduit itself protects the wiring from stones and chafing.
| Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 406
I used flexible conduit under the floor to join each seat box securely fixed using compression glands at each point. I ran a 50 amp cable for positive and negative to a new blue seas fusebox sited under the drivers seat. I did use a properly fixed megafuse in the battery box for that cable run. 👍 2015 90 XS Santorini Black
