Page 1353 of 1391 <123 ... 135213531354 ... 138913901391>
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
No ewe turns Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #1000468 17th Jul 2023 8:17am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
mrandmrsh wrote:
Not posted for years but this weekend I did a thing! Took part in a moving art project related to our Town’s music festival. [url] https://www.instagram.com/reel/CuubcgCIieY...OQ==[/url]
Good fun seeing people hot and bothered putting their shopping away smile and laugh as I drove past. 9 of us joined in.
Adding a RAM Air system doesn’t actually mean add a Ram in the air… Rolling with laughter Rolling with laughter Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #1000469 17th Jul 2023 8:55am
ChrisCSL
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Fitted the Nakatanenga Rear Door Gas Strut I had purchased from MUD UK a few weeks back.
I'd never drilled a holes in my Defender before or used a rivet gun. I didn't even break any door trim clips.
Turned out nice and easy and now the rear door doesn't swing back into me, stays open.
Very pleased Thumbs Up
Post #1000570 17th Jul 2023 5:43pm
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
Just finished brushing and prepping the headlining backs in readiness for the new material arriving to recover them. 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1000572 17th Jul 2023 5:54pm
excossack
Over a couple of trips last night me and Mrs E moved nearly a tonne of MOT hardcore in the 110.
The landy felt quite stable and maybe smoother with the additional weight in the rear.
Just needs another hoover now as a bag split! Sad 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1002655 2nd Aug 2023 9:02am
Defendertomten
Sweden 2000 Defender 130 Td5 HCPU Coniston Green
Burned header joint change
Have had the panel apart for long now, but suddenly it happens😀
Borrowed a crimp tool today and changed one of the red sumitomo hm090 joint to a new one. Took almost 2 hours in the dark to do it.
The company who kitted my defender with extras like heated seats to the light cable. Not that smart.
S
Aftermath; should have done this 15 years ago when the light started flickering. Not to much work.
 Land Rover owner since 2003
2008 Disco3 manual
2000 Defender 130 td5 snorkel warn m6000
Post #1003828 12th Aug 2023 12:44am
excossack
A present for the 110 arrived today. Thanks Winchester gears/Ashcrofts Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004954 21st Aug 2023 11:06am
geobloke
I know what that is Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #1004956 21st Aug 2023 11:17am
excossack
hahaha. Its a tidy bit of kit. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004960 21st Aug 2023 11:34am
geobloke
It certainly is Thumbs Up Rear diff refurb is the job for this weekend coming... weather dependant Rolling Eyes
Post #1004961 21st Aug 2023 11:53am
excossack
Good luck. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004966 21st Aug 2023 12:20pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
Spent evenings last week fixing up a new falt dog rack to my canopy and finalising all the smaller parts for the cab. Durite lorry reversing camera instead of a rear view mirror and wiring in the last lights and amber beacons etc.
 Defender 130 HCPU TD5
Series 2a 300tdi
L663 5.0 V8
Post #1004973 21st Aug 2023 12:47pm
excossack
Nice 130. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1004974 21st Aug 2023 12:53pm
excossack
Fitted the Bison rear door strut.
Lack of instructions with the kit and took some time pondering the best way to fit it.
The strut came with two brackets, some rivets and the strut.
I used the original body side bolts to mount one bracket and then lined up and drilled/riveted the door side bracket.
Pros
Door is a lot easier to open with assistance from the ram and the door mounted spare wheel now stops short of the body
Cons
No instructions to give a rough idea of fitting
Door card needs to be altered to fit around the door side bracket.
The nuts for the lower door hinge just touch the body side bracket
I do need to adjust the body side door catch as you need to give the door a hard shut to make the latch click into the position to be locked by a key, but I think the issue is I am now up against the door rubber part that sits on the lip around the door frame.
I may look to cut a section of the door rubber away to give extra adjustment. mmm 1999 Defender TD5 110
Regards
John M0VAZ
Post #1007834 16th Sep 2023 3:06pm
geobloke
How are your balls John? Shocked
And by that I mean the brass balls in the hinges. Replacing these does make a nice difference if they have worn flat.
Post #1007836 16th Sep 2023 3:10pm
