Home > Maintenance & Modifications > larger fuel tank
kljw
larger fuel tank
hi all
does anyone know if a larger fuel tank can be fitted to the 07 defender? feel the standard tank is a little small and range of 280mils between fills is not that good. Cheers
keith
puer claudius
Post #9992 21st Apr 2009 9:03am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Re: larger fuel tank
Laughing Greg & I would probably beg to differ!
There was an option of a second tank for the 50th - James French offered one with a double filler neck - so you still only have the one fuel cap. This was for petrol, but I'm sure the same could be done for diesel.
As I remember the 2nd tank is smaller than the main, but maybe up to 2/3 the size...
PS - It's coming back to me now - I think it involved repositioning the battery box from under the passenger seat, and fitting the 2nd tank there - you then have a pump switch on the dash to top up the main as it empties - so no 2nd guage required etc.
Post #9993 21st Apr 2009 9:21am
Glynparry25
I am not too sure about the 90s but you can get tanks that sit in the rear wings of the 110s.
Have you tried somewhere like this? http://www.safari-equip.co.uk/index.php?page=4. Maybe message them to see if they either have one or are getting ones in for the TDCi.
HTH
Glyn
Post #9996 21st Apr 2009 10:03am
RickA
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Fuel Tank
Hi,
I have the 'FrontRunner' aux tank fitted to my 110 Tdci, fitted under the rear wheel arch between the filler and the main tank, but I don't think they make one to fit the 90.
Devon 4x4 supplied my tank to give them a call.
(Safari Equip took 3 weeks to reply to my enquiry...)
Cheers, Rick.
Post #10001 21st Apr 2009 10:24am
kljw
Hi Guys
thanks for the info, i will start ringing around to day to see what i can come up with. Cheers
keith
puer claudius
Post #10003 21st Apr 2009 10:58am
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
I have a frontrunner aux tank fitted to my 90. the tank sits under the drivers side and has a separate filler just behind the drivers door.
 Land Rover's don't leak oil, they simply mark their territory!
Post #10008 21st Apr 2009 3:56pm
Grockle
Shorty whats the second tank capacity 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #10011 21st Apr 2009 4:58pm
shorty
45 litres. The tank has a separate pump which pumps fuel from aux into main. I believe I am still able to install a third tank under the passengers side to! Land Rover's don't leak oil, they simply mark their territory!
Post #10012 21st Apr 2009 5:01pm
Grockle
looks a neat job, Thumbs Up 2.4 90 XS
Post #10013 21st Apr 2009 5:05pm
mse
280miles is a little low - 20-40more is what i tend to get - although still not brilliant Mike
Post #10019 21st Apr 2009 6:35pm
discocuzzy
Allisport also do them....standard fitment and custom designs Thumbs Up You cannot teach stupid people to do clever things
Post #10020 21st Apr 2009 6:43pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Keith has an auto box, which won't help the mileage One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #10043 21st Apr 2009 11:45pm
mse
Good point Mike
Post #10070 22nd Apr 2009 4:32pm
bell-auto-services
Andrew & Allisport i think is the best option, he has a puma of his own that he has already fitted a second tank to.
Pete
Post #11178 21st May 2009 10:05pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
As Pete said give Andy a call at Allisport , they can make any shape tank you need Thumbs Up
I`ve just fitted one on my 110 dc that i made there, it fits under the passenger rear arch and has a separate pump to transfer to the main tank as need.
Post #11181 21st May 2009 11:30pm
