![]() | Home > Maintenance & Modifications > larger fuel tank |
| kljw Member Since: 23 Jan 2009 Location: Edinburgh Posts: 266
hi all
does anyone know if a larger fuel tank can be fitted to the 07 defender? feel the standard tank is a little small and range of 280mils between fills is not that good. Cheers keith puer claudius |
| Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015
I am not too sure about the 90s but you can get tanks that sit in the rear wings of the 110s.
Have you tried somewhere like this? http://www.safari-equip.co.uk/index.php?page=4. Maybe message them to see if they either have one or are getting ones in for the TDCi. HTH Glyn |
| RickA Member Since: 13 Jan 2009 Location: Preston, Lancs. Posts: 18
Hi,
I have the 'FrontRunner' aux tank fitted to my 110 Tdci, fitted under the rear wheel arch between the filler and the main tank, but I don't think they make one to fit the 90. Devon 4x4 supplied my tank to give them a call. (Safari Equip took 3 weeks to reply to my enquiry...) Cheers, Rick. |
Hi Guys
thanks for the info, i will start ringing around to day to see what i can come up with. Cheers keith puer claudius |
| shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160
I have a frontrunner aux tank fitted to my 90. the tank sits under the drivers side and has a separate filler just behind the drivers door.
Land Rover's don't leak oil, they simply mark their territory! |
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
Shorty whats the second tank capacity 2.4 90 XS
45 litres. The tank has a separate pump which pumps fuel from aux into main. I believe I am still able to install a third tank under the passengers side to! Land Rover's don't leak oil, they simply mark their territory!
looks a neat job,
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
280miles is a little low - 20-40more is what i tend to get - although still not brilliant Mike
| discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200
Allisport also do them....standard fitment and custom designs
| alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513
Keith has an auto box, which won't help the mileage One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
Good point Mike |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Andrew & Allisport i think is the best option, he has a puma of his own that he has already fitted a second tank to.
Pete |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505
As Pete said give Andy a call at Allisport , they can make any shape tank you need
I`ve just fitted one on my 110 dc that i made there, it fits under the passenger rear arch and has a separate pump to transfer to the main tank as need. |
