Home > Puma (Tdci) > Station wagon 07 Puma 2.4 idling problem...help please! |
GeorgeTDI07 Member Since: 14 Jan 2019 Location: Suffolk Posts: 5 |
Thanks for all the comments we're going to change the VCV again before looking at the high pressure pump - we haven't been able to complete a 'pump learn procedure so the problem does seem to be in teat area.....
16th Jan 2019 11:45am |
Also going to replace the clutch switch...!
16th Jan 2019 11:46am |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
They'll run ok without a pump relearn, so fit another vcv a give it a go
16th Jan 2019 1:31pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19579 |
There is a lot of confusion (deliberately?) with sellers of VCV’s if they are brand new or recon. Never a clear answer hardly but a distinct significant price difference is rather telling. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
16th Jan 2019 1:42pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 325 |
Buy the valve only original from Denso (part number DCRS300260). With *bay (usually from UK) forgeries are sold at the half price. Ford prescribes the exchange together with the PRV (pressure relief valve). Would follow that recommendation...
16th Jan 2019 4:51pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
Are you sure you haven't got air getting into the fuel lines?
Could be a dodgy fuel filter, loose injector pipes? I had a cheap fuel filter once that restricted fuel flow. It would start fine but once it emptied the can it would cut out. Just a thought Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
16th Jan 2019 10:24pm |
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 |
Hi Did you get this sorted in the end?
23rd Jan 2019 7:41pm |
