Home > Puma (Tdci) > Station wagon 07 Puma 2.4 idling problem...help please!
Page 2 of 2 <12
jst
i had similar changed VCV no difference, repalced again it worked.
VCV dont awlays work out the box. one i fitted on my own vehicle didnt even let the car start!
didnt do any relearns. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #751565 15th Jan 2019 11:01pm
GeorgeTDI07
United Kingdom 2007 Defender 110 Puma 2.4 SW Indus Silver
Thanks for all the comments we're going to change the VCV again before looking at the high pressure pump - we haven't been able to complete a 'pump learn procedure so the problem does seem to be in teat area.....
Post #751655 16th Jan 2019 11:45am
GeorgeTDI07
Also going to replace the clutch switch...!
Post #751656 16th Jan 2019 11:46am
williamthedog
They'll run ok without a pump relearn, so fit another vcv a give it a go Thumbs Up
Post #751683 16th Jan 2019 1:31pm
There is a lot of confusion (deliberately?) with sellers of VCV’s if they are brand new or recon. Never a clear answer hardly but a distinct significant price difference is rather telling. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #751685 16th Jan 2019 1:42pm
hornet
Buy the valve only original from Denso (part number DCRS300260). With *bay (usually from UK) forgeries are sold at the half price. Ford prescribes the exchange together with the PRV (pressure relief valve). Would follow that recommendation...
Post #751713 16th Jan 2019 4:51pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Are you sure you haven't got air getting into the fuel lines?
Could be a dodgy fuel filter, loose injector pipes?
I had a cheap fuel filter once that restricted fuel flow. It would start fine but once it emptied the can it would cut out.
Just a thought Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #751792 16th Jan 2019 10:24pm
Tomotomo
Hi Did you get this sorted in the end?
Post #753435 23rd Jan 2019 7:41pm
Page 2 of 2 <12
