Home > Td5 > Cruise control not working after installing auto box |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4401 |
That is fantastic news MSB WELL DONE
20th Mar 2018 7:57am |
Top work msb thanks for posting this as I'll need to do it when I get mine installed. Ray
20th Mar 2018 6:39pm |
Just one more question if you can remember, you say you fitted a disco switch, can you remember which colour wires on the switch went to which pin on the ecu? On the switch I have a green a blue and a black and the diagram shows a red a green and an orange Cheers Ray Ray My build thread http://www.defender2.net/forum/topic17615.html |
20th Mar 2018 6:45pm |
msb Member Since: 28 Feb 2013 Location: Leeds Posts: 77 |
The on/off switch is a separate toggle switch, so that's the red on the diagram, feeding 12v into the disco swtich.
The Disco switch has the SET and RES functions, and I've just had a look on ebay and eBay Item No. 183130961613 (which also includes a nice on/off toggle switch) shows three wires; one will be the power in from the on/off toggle switch, and the other two will be when the SET and RES buttons make the respective circuits. I'm not with the car at the moment, so can't check anything, but a mutlimeter and pressing the switches will tell you which of the three is which. HTH Cheers Mike |
20th Mar 2018 11:24pm |
sherifsalem Member Since: 02 Jan 2013 Location: Porto Posts: 96 |
Hi Gents,
for anybody interested this peice of equipment works fine and one of the best modes for long landy overland drives to Morrocco or Mauri the cruise control from Nakatamenga https://thegippo.wordpress.com/2018/01/23/...e-control/ hope it helps Happy Travel www.thegippo.wordpress.com |
16th Sep 2018 3:49pm |
