Home > Td5 > Cruise control not working after installing auto box
Page 1 of 4 1234>
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
A few months ago I had a manual 2004 Td5 with a NNN50020 ECU and functioning cruise control.
Due to the rust ( Question ) in the ECU killing it on the way to Ashcroft's I now have an auto 2004 Td5 with a NNN50020 made from a NNNsomething else ECU by Gary at Alive and non functioning cruise control.
I'd like to get the cruise control working again, but appreciate having changed several things at once is not the best starting point.
Has anyone had to change anything after as auto conversion to keep the cruise control working?
The transfer box hasn't changed, so I don't think I need a speedo healer (and don't want to spend £80 if I don't have to) so I suspect it may be to do with the clutch switch, but work and the weather have prevented me from investigating too far as yet.
Does anyone have any more thoughts or suggestions?
Thanks
Mike
Post #675874 4th Jan 2018 8:38pm
grafty99
I think the clutch switch is push to break so the two wires need to be joined for the ecu to think the clutch isn't pressed Thumbs Up
The cruise control doesn't work on a manual if you unplug the switch Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #675875 4th Jan 2018 8:45pm
msb
Thanks grafty, that's pretty much where I'd got to (but couldn't remember if the circuit was normally open or closed).
If I just make sure there's 12v at pin 35 I should be right then, shouldn't I?
Thanks
Mike
Post #675880 4th Jan 2018 8:50pm
grafty99
Yes it should do the trick. Unless you bridge the connection under the bonnet? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675891 4th Jan 2018 9:06pm
msb
As I didn't do the conversion (Ashcroft's did) I'm not sure what happened to that circuit, and Dave (surprisingly) wasn't offering any help...
I'll try pin 35 and see what happens. I'm guessing I can tap off a supply voltage on a nearby pin.
Post #675894 4th Jan 2018 9:15pm
grafty99
Yeah that would do, if the wiring isn't obvious under the bonnet then an under seat connection would be easier Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675902 4th Jan 2018 9:27pm
msb
I'll have another look under the bonnet if it is ever light enough and dry enough when I'm at home as compleing the circuit there (if it is there) would probably be easier, but if the clutch circuit is open wouldn't that reduce overall power?
I thought that circuit dropped the throttle output, or limited revs, or something to promote smoother gear changes. That was the reason I did have a separate switch in it previously to keep it closed when trialling or competing....
Back to being confused again now... Rolling Eyes
Post #675906 4th Jan 2018 9:40pm
grafty99
It rev hangs and generally softens throttle response. Probably not noticeable on an auto though.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675907 4th Jan 2018 9:44pm
msb
That makes sense I guess.
I'll give it a whirl tomorrow or Saturday.
Thanks for your help.
Post #675909 4th Jan 2018 9:49pm
grafty99
No worries Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675914 4th Jan 2018 9:59pm
MadTom
There are some small differences in TD5 ECU for manual. Auto ECU has CAN driver for communication with Disco2 auto ECU, and is missing circuit (some resistors) for clutch pedal sensing. I ha modified some auto ECUs to use in manual - replacing the whole software (not just remap) and adding those missing resistors. The rest is the same.
Corrosion inside ECU is not unknown - normally after drowning, but it can be also because of humidity in car. ECU internal are covered with some conformal coating (looks like a silicon) to protect them from moisture, but it is not 100%. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #675988 5th Jan 2018 7:59am
grafty99
I doubt that they would have changed the ECU when converting to auto, especially as there are no defender auto specific maps. Also if the vehicle was previously tuned then they would loose the tune which I'm sure wouldn't impress the customer! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #675991 5th Jan 2018 8:37am
AJC
Grafty, have you got cruise on your TD5?
Post #675996 5th Jan 2018 8:59am
grafty99
I do yes Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #676002 5th Jan 2018 9:13am
MadTom
I agree with the change of ECU. There is a bigger problem with the change of gearing - manual gearbox has different gearing from auto gearbox. So the speedo healer may not be enough to overcome this.
Engine ECU has some ratio ranges limits between RPM and vehicle speed, more than one, because cruise control works not only in fifth gear. And with auto gearbox this Is totally different. When the auto gearbox is locked, than the ratio is fixed, but when not, than the ratio changes, as the car speed is rising and the torque convertor is slipping. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #676005 5th Jan 2018 9:50am
Page 1 of 4 1234>
