Home > In Car Electronics > Tablet advice |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 |
Google maps allows you to download a defined area, not just a single route. I have not checked to see whether it is a cut-down map with only highways, but it is certainly an area that you can specify. I tend to use it for all of my road work, but for anything away from the roads have the OS maps and a Garmin 62S with OS map card, or worst case a paper equivalent. |
11th Nov 2017 8:45pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
Offline Google Maps is great, it has points of interest, routing and all sorts.
It doesn't have quite as much information as the online one (like opening hours and reviews) but works well enough to navigate to a hotel when your Venezuelan driver has got lost... However, you can only download a small-ish area. For large areas offline, I use Here maps, which generally work well. For greenlanes and stuff, I use a combination of things. To plan the routes I use the GLASS Trailwise website along with Bing's OS maps. I then plot the route on to my phone running Locus Maps and the Open Street Map data. OSM data is clearer than OS data and it's vector maps rather than images so uses a huge amount less space. I've used both OS and OSM, and the OS data is better at identifying rights of way but the OSM stuff is much easier to use becuase it zooms and scales better. Before using Locus I used Backcountry Navigator which is fine, but not a patch on Locus. I've tried Viewranger and don't get on with it, in particular downloading large areas of mapping which is a pain. Locus just makes it really easy. |
13th Nov 2017 10:32pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Can’t say if it’s “the best app” but I use Gaia GPS to look for and register. |
14th Nov 2017 10:16am |
