Home > Puma (Tdci) > Help diagnosing intermittent random engine cut-out |
MMMC Member Since: 10 Jan 2020 Location: Wakefiels Posts: 3 |
Hi - Has anyone been able to sort this problem out? My car has been in the auto electrician all week and he still can't find the issue. Help would be much appreciated. Cheers Marcus
10th Jan 2020 2:53pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3693 |
Hello
Sorry I thought I had updated this post Mine has 'touch wood' vbeen sorted now since changing the rear part of the ignitian barrel. All have worked perfectly, it must have been an iffy contact evey now & again just failing then coming back on. Cheap fix in the end and piece of mind restored Hope your s is similar fix |
10th Jan 2020 3:00pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2288 |
Reading the various threads on Intermittent Starting / Cut Out problems
If I was faced with this (again) I would 100% swap out the ignition switch, just to take it out of the equation mine was intermittently not starting... it never cut out when running but it looks as though some do. The Ignition Switch is cheap to buy (probably part of the problem) and depending on what your set up is can be a to replace...not difficult just involved Here's my fix 2 years later all OK and (I carry a spare just in case) https://www.defender2.net/forum/topic56773...p;start=45 SKIP https://www.defender2.net/forum/topic83242.html |
10th Jan 2020 3:16pm |
Thanks to both of you for your help. I have just spoken to my auto electrician and he is ordering a new ignition switch. I'll update when I know more.
10th Jan 2020 3:37pm |
Good Luck MMMC SKIP
10th Jan 2020 3:43pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 800 |
My problem went away when I started using better fuel - see this thread https://www.defender2.net/forum/topic69868.html
I mainly do short journeys, and I suspect sensors were getting mucky between longer runs. |
10th Jan 2020 5:07pm |
That certainly is interesting. I've been using Morrisons fuel for quite a long period of time and also Jet. I will make the change! Cheers
10th Jan 2020 5:23pm |
dannyragsdale Member Since: 07 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 |
Looks like I am joining the group of intermittent cutouts. Going to be checking all the things listed, but did the ignition barrel fix things for you too, MMMC?
25th Dec 2023 10:17am |
