Home > Maintenance & Modifications > Extended arches which don't require drilling/cutting? |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
Looks like I found some, ask and the internet shall provide: http://www.tomcatwebshop.co.uk/wide-flexi-...-138-p.asp
Tell me if i'm wrong? |
19th Mar 2017 1:42am |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 |
Project Kahn do a set
Click image to enlarge |
19th Mar 2017 10:43am |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
Ha, they are only £2400 fitted!
21st Mar 2017 10:53pm |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3321 |
You're not wrong, they do come in straight lengths I believe that you have to bend into shape to fir the bodywork |
21st Mar 2017 11:23pm |
Arierep Member Since: 13 Apr 2013 Location: Portugal Posts: 258 |
I too would be interested in a no drill solution for wider flares.
I just changed my wheels to 16x8 -25 offset, and with 255/85R16 they're on the verge of illegality. If I go for 285/75R16 or 315/75R16 ( more likely) I'll absolutely need wider arches. An elongated open "D" profile would do the trick. It would attach to the wing and then the original flare would attach to it. No rivets would be visible. It should be made in high density PUR, which has all the perfect properties for the application. Also, PUR injection molds are much cheaper than plastic injection molds. You can get one for 10k euros or less for low production volumes. |
17th Jul 2017 11:20pm |
