Home > Maintenance & Modifications > Extended arches which don't require drilling/cutting?
Page 2 of 2 <12
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Looks like I found some, ask and the internet shall provide: http://www.tomcatwebshop.co.uk/wide-flexi-...-138-p.asp
Tell me if i'm wrong?
Post #610463 19th Mar 2017 1:42am
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
Project Kahn do a set
Post #610509 19th Mar 2017 10:43am
Lancerdoc999
Ha, they are only £2400 fitted!
Post #611254 21st Mar 2017 10:53pm
camelman
You're not wrong, they do come in straight lengths I believe that you have to bend into shape to fir the bodywork
Post #611264 21st Mar 2017 11:23pm
Kit
£200 seems a bit steep but they're the only ones i've found so far which don't require the wings to be drilled.
Would anyone be interested in a group buy?
Post #611297 22nd Mar 2017 12:57am
Arierep
Portugal 1995 Defender 90 300 Tdi SW Alpine White
I too would be interested in a no drill solution for wider flares.
I just changed my wheels to 16x8 -25 offset, and with 255/85R16 they're on the verge of illegality. If I go for 285/75R16 or 315/75R16 ( more likely) I'll absolutely need wider arches.
An elongated open "D" profile would do the trick. It would attach to the wing and then the original flare would attach to it. No rivets would be visible.
It should be made in high density PUR, which has all the perfect properties for the application. Also, PUR injection molds are much cheaper than plastic injection molds. You can get one for 10k euros or less for low production volumes.
Post #638135 17th Jul 2017 11:20pm
Page 2 of 2 <12
