Home > Td5 > 15W40 oil okay for the TD5? |
BCdefender Member Since: 26 Oct 2015 Location: Nanaimo Posts: 211 |
Just did an oil and filter change with 15W/40. The manual says 5W/40 and doesn't mention the 15W.
Is there a potential problem in using 15W/40 in the TD5? Thanks 1999 Defender 110 2003 P38 2007 RR SC "And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it." My build thread: http://www.defender2.net/forum/topic47750.html |
21st Jan 2017 6:23am |
Yeah 15w40 will be too viscous when cold so won't lubricate the engine properly on cold starting. Stick with the recommended 5w30 2002 90 Td5 Station Wagon
1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 21st Jan 2017 11:48am. Edited 1 time in total |
21st Jan 2017 10:49am |
Fully synthetic too 2002 90 Td5 Station Wagon
21st Jan 2017 10:51am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1759 |
I'd say not, too thick when cold.
Also would personally buy more specific td5/of engine oils. |
21st Jan 2017 11:47am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2262 |
It won't harm the engine but will use a little more fuel.
You will only get actual lubrication issues at temperatures below about -20 deg C |
21st Jan 2017 12:00pm |
Raywin Member Since: 27 Feb 2015 Location: North Yorkshire Posts: 48 |
I like to use 5w 40 in mine, I find that the engine is a bit quieter than when I use 5w 30 probably starting to get a bit more clearance in the journals now. Ray
21st Jan 2017 12:02pm |
If his avatar is right he lives in Canada so -20c is highly likely! 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
21st Jan 2017 12:28pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
I'd be concerned with the 15W when it gets to zero or near zero. Stick wth the 5W and fully synth. Winter in Nanaimo is a lot milder than here in the Ottawa Valley but be wary of low temps when you use 15W oil. Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
21st Jan 2017 1:56pm |
Well yes, in Canada l'd be looking at 5w/30 or 5w/40 for the reasons stated above.
I did not notice l thought he was in the UK! |
21st Jan 2017 2:25pm |
On Vancouver Island it rarely gets below zero at sea level but obviously once you head into the mountains the temperature quickly drops. Regardless it sounds like 5W 30/40 synthetic is the consensus. Thanks again.
21st Jan 2017 4:37pm |
