Home > Td5 > 15W40 oil okay for the TD5?
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Just did an oil and filter change with 15W/40. The manual says 5W/40 and doesn't mention the 15W.
Is there a potential problem in using 15W/40 in the TD5?
Thanks 1999 Defender 110
2003 P38
2007 RR SC
"And that's why it needs to be celebrated, because when the Defender goes we'll have lost this pointer to where we came from, and we're really going to miss it."
My build thread: http://www.defender2.net/forum/topic47750.html
Post #594894 21st Jan 2017 6:23am
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
The first digit (in this case 15 or 5) denotes the viscosity of the oil at low temperatures: the lower the number, the more fluid the oil is when cold. If your profile is correct you are living in a beautiful yet very cold part of the world. Maybe other people can tell you otherwise out of experience, but I wouldn't feel at ease with 15W...
Greetings,
Joris
Post #594917 21st Jan 2017 10:15am
grafty99
Yeah 15w40 will be too viscous when cold so won't lubricate the engine properly on cold starting. Stick with the recommended 5w30 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #594928 21st Jan 2017 10:49am
grafty99
Fully synthetic too Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #594929 21st Jan 2017 10:51am
miker
I'd say not, too thick when cold.
Also would personally buy more specific td5/of engine oils.
Post #594938 21st Jan 2017 11:47am
lightning
It won't harm the engine but will use a little more fuel.
You will only get actual lubrication issues at temperatures below about -20 deg C
Post #594941 21st Jan 2017 12:00pm
Raywin
United Kingdom 2001 Defender 90 Td5 HT Java Black
I like to use 5w 40 in mine, I find that the engine is a bit quieter than when I use 5w 30 probably starting to get a bit more clearance in the journals now. Ray
Post #594942 21st Jan 2017 12:02pm
grafty99
If his avatar is right he lives in Canada so -20c is highly likely! 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #594948 21st Jan 2017 12:28pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
I'd be concerned with the 15W when it gets to zero or near zero. Stick wth the 5W and fully synth. Winter in Nanaimo is a lot milder than here in the Ottawa Valley but be wary of low temps when you use 15W oil. Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #594953 21st Jan 2017 1:56pm
lightning
Well yes, in Canada l'd be looking at 5w/30 or 5w/40 for the reasons stated above.
I did not notice l thought he was in the UK!
Post #594959 21st Jan 2017 2:25pm
BCdefender
On Vancouver Island it rarely gets below zero at sea level but obviously once you head into the mountains the temperature quickly drops. Regardless it sounds like 5W 30/40 synthetic is the consensus. Thanks again.
Thumbs Up 1999 Defender 110
2003 P38
2007 RR SC
Post #594981 21st Jan 2017 4:37pm
