Home > Tdi > 200Tdi Race engine - Weak points and limitations |
Boost Member Since: 17 Oct 2014 Location: Gloucestershire Posts: 198 |
I use this seller mate
http://www.ebay.co.uk/itm/ASH-Straight-Sil...YBQiOD9GRQ |
9th Feb 2017 12:09am |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2069 |
+1 on ASH got some on my 110.
Also this is pretty awesome who woulda thought you could squeeze this much power from such an old engine! Good job |
9th Feb 2017 11:29am |
My mate and I made a quick film today
10th Feb 2017 12:51am |
thats an awesome video! Proper Top Gear style. A man of many talents I see!
Goes brilliantly and not too smokey, i was expect clouds of black smoke! |
10th Feb 2017 9:13am |
Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 311 |
Looking good Boost!
How's the water injection coming along? Isn't 14psi a bit conservative ?? Thought you would have gone full blown rocket ship by now lol Did you ever get a price for the ARP's? |
10th Feb 2017 1:04pm |
Thanks for the kind words!
14psi is the turbo’s stock wastegate setting, we knew someone would pick up on this Will look into getting up to 30psi out of it with a boost controller later today! Water-injection’s next up, expect a vid soon Matt I’m on it, if you’re sure those stud measurements are correct from earlier, will double check and contact a retailer then get back to you. |
10th Feb 2017 3:58pm |
A facelift (Thanks L90Andy )
Click image to enlarge Click image to enlarge |
14th Feb 2017 3:25pm |
Loving the face lift 2002 90 Td5 Station Wagon
14th Feb 2017 6:33pm |
Cheers grafty
Had an interesting issue the other night whilst pinning it through the gears. Got into 5th and the engine died, accelerator pedal didn't respond and would only rev after I pushed the clutch in. Problem went away when put into a lower gear but really odd, total loss of power as if the gear had sheared off or something! Went for a drive afterwards and problem's gone but could it be fuel starvation possibly? Might change the fuel filter just to be safe. |
14th Feb 2017 9:24pm |
Fuel filter is a good place to start. Also check your fuel tank breather. Open the fuel cap and check there isn't suction as you open it. If it is blocked then the vacuum in the tank could over come the fuel pump preventing sufficient fuel delivery 2002 90 Td5 Station Wagon
14th Feb 2017 11:08pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10513 |
Nice face lift Boost 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
15th Feb 2017 9:45pm |
Thanks for the tips grafty, gonna go through everything when I order a new filter.
New vid's up, any Series fans out there? Best look away |
16th Feb 2017 11:45pm |
Nice intro, can wait for the full length video 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
16th Feb 2017 11:50pm |
Awesome mate I still need to pm you about those hoses, sorry been a bit busy but I'll post some pics if you like?
16th Feb 2017 11:54pm |
