Home > Puma (Tdci) > Wild bear Diff Guards, I've mixed up the brackets
Iktank
Wales 2014 Defender 90 Puma 2.2 SW Corris Grey
Puma 90 diff Guards front and back
If any one has fitted these, I gone and mixed up which bracket went with which
To save me climbing about underneath when I go to fir these be appreciated if any one knows
There is a flat top plate with round holes or a slightly gimped top plate with oval holes in
Post #568241 2nd Oct 2016 5:45pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
There are a few people on this thread that recently fitted them front and back so should be able to help
http://www.defender2.net/forum/topic35405-30.html
Post #568282 2nd Oct 2016 7:37pm
Iktank
Sorted
As per my pictures, they were paired correctly
Took all in 4hrs
- 9.15am put landy on ramp in mates workshop
- 9.30ish make cups of tea
- 9.40ish fetch breakfast rolls
- 10.00 start working on diff guards
- 1.00pm finished Smile most of my time lost trying to find M10 metric fine bolts, then cutting them to correct length and cleaning out predrilled holes in the diff, had to use a proper thread cutter/cleaner
I found the diff gurds fit not to bad, insted of fitting the top bracket to the main body of the diff guard with the bolt facing down (as per pictures) I screwed the bolt facing upwards throught he treaded section of the diff guard.
This enabled the bolt to be held in place and made it easir to locate and support the top bracket. I then used a nut (not supplied) to pull and fix the parts together
Soooooo much easier.
Also the supplied bolts for the rear diff guard are not correct for my Puma, the pitch of the thread was wrong, the predrilled holes in the diff are M10 - metric fine (the bolts supplied were neither metric fine or UNF - could not work out what they were)
Hope this helps someone else
Post #571161 16th Oct 2016 7:38am
