Home > Technical > Show me your Anderson Connectors.
Page 2 of 2 <12
landy andy
I was going to fit one of those boot things to mine, but if you do you are likely to hold water inside the connector, where without one fitted any moisture would just run away. People talk about corrosion issues, but these connectors are used in many places and I'm yet to see a failed one. Mine had a quick spray of battery terminal spray when installed, and I have never had any issues. These are better than most jump leads that people are using.
Post #405284 7th Mar 2015 1:41pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
THanks for the info and photos guys
I will be fitting mine to my seat box.
G My confidence has been writing cheques that my abilities can't cash for years.
Post #405479 8th Mar 2015 12:05am
gavinpm
England 2006 Defender 90 Td5 SW Cairns Blue
Here's mine - on the seat box
Post #405499 8th Mar 2015 8:46am
K9F
Here's anolther. Must be just in the marine environment they corrode. Little wonder I have no faith in them. This one had only been fitted for about three months. Shocked
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #405665 8th Mar 2015 5:39pm
walfy
TBF anything in the marine enviroment will corrode due to the slat in the water. I very much doubt there will be many on here who put their pride and joy anywhere near salt water. I know I don't.
I'll be fitting an anderson to the front of my 110 when I can find time to sort it out and the pennies for the cabling. 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #405675 8th Mar 2015 6:18pm
leeds
Looking at that photo that left hand contact appears to have all the silver plating removed and to be suffering from copper 'corrosion or oxidisation. Presumably left where salt water or spray could get at it?
Have not heard of anything like that in the 4x4 world. OK a Defender cab might get moist but not that moist and not in corrosive content. Personally I do not see any issues with using an Anderson connector on a Defender.
Their are genuine Anderson connectors, there are good quality high current DC connectors such as Rema and then there are the cheap copies. If tempted to buy the cheap copies have a good look at the contacts. On genuine Anderson connectors the contacts are smooth and silver coated. On the cheap copies the surface can be extremely rough, lumpy, pitted etc from new. This means that the actual contact area is much smaller and that arcing might occur in between the contacts which is not good news.
Brendan
Post #405678 8th Mar 2015 6:38pm
K9F wrote:
Shocked do you dangle them over the side as you are going along?
Remind me never to buy any second hand parts from your part of the world.
Post #405813 8th Mar 2015 11:09pm
K9F
No need the North is flooded with second hand parts from Defenders apparently. If not it should be according to Landywatch.
http://www.landywatch.co.uk/index.php/stolen-vehicle-maps/ If you go through life with your head in the sand....all people will see is an ar5e!!
Post #405817 8th Mar 2015 11:15pm
jimbob7
Anderson leads are used externally for powering tail lifts on hgv's,exposed to all weathers, road spray and driver abuse,I would expect an anderson lead inside a Defender to last forever Pov.spec,ftw. 2006, 110,TD5.
Post #405920 9th Mar 2015 11:56am
Page 2 of 2 <12
