Home > Maintenance & Modifications > any link between no filler cap and engine warning light?... |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2289 |
Just thought I would add to my Engine Warning Light issue recently
or MIL (Malfunction Indicator Lamp)... Installed the ScanGaugeII...simple enough, Set up also simple, so far from me... Checked for Logged Error Codes DTC (Diagnostic Trouble Code) and got... Click image to enlarge So the same as Venomator recently. Click image to enlarge There is online information on this and it has been covered on Def2Net K9F was right, mine reset itself after a few driving cycles (about 6). http://www.defender2.net/forum/post69774.html I will keep an eye on this, now possible with the ScanGauge, will also check fuel consumption which appears to suffer if the MAF (Mass Air Flow) Sensor is failing... so far no re-occurrence. Thanks again for the help from the Forum... SKIP https://www.defender2.net/forum/topic83242.html |
1st Mar 2015 6:00pm |
