Home > Technical > Speedo cable end size? |
Timo Member Since: 14 Jul 2011 Location: Peterborough Ontario Posts: 171 |
Hi all
I am trying to fit the square end of the speedo cable from my 1984 v8. 110 into the R380 from a disco that is now in my defender My square cable end is 3.0mm The transducer that I removed square end is 2.6mm end Would there be different sizes? Spent a good hour today trying to get them to mate up with no luck....... Any help is appreciated Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
23rd Jun 2014 3:06am |
Jim - thanks, yes it is the LT95. I will see if I can pull that piece out first before I buy a new cable
Cheers Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
23rd Jun 2014 2:58pm |
OK, so I removed the transducer and tried to plug my speedo cable in but it appears that it is a different size (the square hole in my R380 tranny (from a disco) is smaller than the square at the end of the speedo cable).
I purchased a new cable thinking it would fit but it this new one is also too big to go into the square that previously held the transducer. Can anyone help share some light on what I am doing wrong? - Disco R380 tranny small square speedo insert - Defender speedo cable too big Thanks Tim Series II in pieces 1984 Defender 110 (3.5l V8 now 300TDI) |
2nd Sep 2014 7:16pm |
That is strange as my 1984 90 cable fitted in my 2003 90 td5 transfer box. Roel
2nd Sep 2014 9:52pm |
