Home > Maintenance & Modifications > Fitting Mammouth checker plate wing tops. |
ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731 |
I used ally rivnuts in the end. My plate came from a German firm - very nice contours but making them impossible to rivet straight on (hence the change of plan to rivnuts). I recessed the screw heads into the plate a little so I could fill them with black Hammerite to hide the fact I was using bright stainless screws, also to seal any leaks (paranoia about bimetallic corrosion - also coated the threads with Duralac!)
I'm now learning not to cut corners and rivnut every time, first time. Doing my security grills again "properly" next week, Brendan Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
29th Apr 2012 2:15pm |
Yep, as I said it's exactly the same as the chequer plate gaskets. A cheap and easy solution Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
29th Apr 2012 4:49pm |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
pm sent |
26th Jan 2013 8:33am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3615 |
Simon - can you remember who this was?[/quote]
pro bolt are good but quite costly found this on ebay Item number:400354973172 blacked stainless steel DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
26th Jan 2013 8:34am |
Not stainless unfortunately - black stainless fasteners would be my "Holy Grail"
... got me all excited for a moment Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
26th Jan 2013 9:28am |
sorry miss read the title , same firm do do loads of stainless though abate silver, I have a set of Mammoth Silver anodised wing tops with gaskets and screws etc but I havnt plucked up the courage to drill the wings yet, and Im thinking black might look better than silver DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
26th Jan 2013 10:23am |
Got mine from here http://www.gwr-fasteners.co.uk/coloured-st...s-14-w.asp
26th Jan 2013 10:55am |
Nice find
Just the job and not so expensive - about £30 (+p&p) for both wings. Can't be bothered to scrape the Hammerite off the ss ones to replace them yet though Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
26th Jan 2013 12:18pm |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
I'm looking to remove my wing checkerplate to have it powder coated & painted black (currently standard 'silver').
If I can get to the rivnuts to hold then as I remove the bolts will I be able to reuse them? or do I have to buy new rivnuts and a tool? Same question for the nylock fasteners please Thanks, Dan. |
22nd Aug 2013 11:59am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Rivnuts should be reusable. They are just a fixed insitu nut.
Reusing nylon nuts? IF it was a safety critical use it would be a big NO NO? However wing tops not exactly safety critical so I personally would not fret about reusing nyloc nuts. Purists might argue you should use new ones. If you have spare ones to hand use them, if not do not worry about reusing them. It depends on application. If safety involved use new ones, correctly torqued etc Brendan |
22nd Aug 2013 12:23pm |
Thanks
22nd Aug 2013 2:24pm |
The big issue with these is whether the fastener gets stuck in the rivnut and/or the rivnut becomes loose or starts spinning making removal very difficult.
Agree on safety critical but for other applications you could just fit a spring washer as belt and braces. Or go the whole hog and swap out for some Binx nuts which are reuseable: |
23rd Aug 2013 11:26am |
Myers Member Since: 07 Dec 2011 Location: Wiltshire / Sailisbury Plain Posts: 156 |
Hi
Could anyone please tell me the size of the bolts that come with the Mammouth CP wing tops? I've orderd mine, but after reading this thread think rivnuts are the wa to go, so need to get some. Thanks in advance |
29th Sep 2013 3:49pm |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3247 |
M6
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
29th Sep 2013 9:39pm |
