Home > Maintenance & Modifications > Fitting Mammouth checker plate wing tops.
Page 2 of 3 <123>
ZeDefender
I used ally rivnuts in the end. My plate came from a German firm - very nice contours but making them impossible to rivet straight on (hence the change of plan to rivnuts). I recessed the screw heads into the plate a little so I could fill them with black Hammerite to hide the fact I was using bright stainless screws, also to seal any leaks (paranoia about bimetallic corrosion - also coated the threads with Duralac!)
I'm now learning not to cut corners and rivnut every time, first time.
Doing my security grills again "properly" next week, Brendan Wink Tell someone you love them today because life is short.
Post #142381 29th Apr 2012 2:15pm
leeds wrote:
Now does self adhesive foam tape come in closed cell
Yep, as I said it's exactly the same as the chequer plate gaskets. A cheap and easy solution Thumbs Up Darren
Post #142419 29th Apr 2012 4:49pm
SGH wrote:
I have the Mammouth ones was planning on using rivnuts as possibly easier option.
Have had made up rear corners and sill covers for my 130 and getting black powder coated and found supplier of black anodised ally countersunk fasteners.
Simon
Simon - can you remember who this was?
Post #205408 25th Jan 2013 11:45pm
SGH
Simon
pm sent
Post #205444 26th Jan 2013 8:33am
LR90XS2011
Simon - can you remember who this was?[/quote]
pro bolt are good but quite costly
found this on ebay
Item number:400354973172 blacked stainless steel DEFENDER 90 TDCI XS,
Post #205445 26th Jan 2013 8:34am
ZeDefender
Not stainless unfortunately - black stainless fasteners would be my "Holy Grail" Thumbs Up
... got me all excited for a moment Sad Tell someone you love them today because life is short.
Post #205451 26th Jan 2013 9:28am
LR90XS2011
sorry miss read the title , same firm do do loads of stainless though abate silver,
I have a set of Mammoth Silver anodised wing tops with gaskets and screws etc but I havnt plucked up the courage to drill the wings yet, and Im thinking black might look better than silver DEFENDER 90 TDCI XS,
Post #205463 26th Jan 2013 10:23am
SGH
Post #205474 26th Jan 2013 10:55am
ZeDefender
Nice find Thumbs Up
Just the job and not so expensive - about £30 (+p&p) for both wings.
Can't be bothered to scrape the Hammerite off the ss ones to replace them yet though Rolling Eyes Tell someone you love them today because life is short.
Post #205492 26th Jan 2013 12:18pm
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Are rivnuts reusable?
I'm looking to remove my wing checkerplate to have it powder coated & painted black (currently standard 'silver').
If I can get to the rivnuts to hold then as I remove the bolts will I be able to reuse them? or do I have to buy new rivnuts and a tool?
Same question for the nylock fasteners please
Thanks, Dan.
Post #260528 22nd Aug 2013 11:59am
leeds
Rivnuts should be reusable. They are just a fixed insitu nut.
Reusing nylon nuts?
IF it was a safety critical use it would be a big NO NO?
However wing tops not exactly safety critical so I personally would not fret about reusing nyloc nuts.
Purists might argue you should use new ones. If you have spare ones to hand use them, if not do not worry about reusing them.
It depends on application. If safety involved use new ones, correctly torqued etc
Brendan
Post #260532 22nd Aug 2013 12:23pm
danridge
Thanks Thumbs Up
Post #260556 22nd Aug 2013 2:24pm
The big issue with these is whether the fastener gets stuck in the rivnut and/or the rivnut becomes loose or starts spinning making removal very difficult.
leeds wrote:
Reusing nylon nuts?
Brendan
Agree on safety critical but for other applications you could just fit a spring washer as belt and braces.
Or go the whole hog and swap out for some Binx nuts which are reuseable:
Post #260793 23rd Aug 2013 11:26am
Myers
United Kingdom 2013 Defender 90 Puma 2.2 HT Epsom Green
Hi
Could anyone please tell me the size of the bolts that come with the Mammouth CP wing tops?
I've orderd mine, but after reading this thread think rivnuts are the wa to go, so need to get some.
Thanks in advance
Post #270147 29th Sep 2013 3:49pm
bob neville
M6 Thumbs Up
2013 Defender 90 CSW - sold
Post #270281 29th Sep 2013 9:39pm
Page 2 of 3 <123>
