Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Thank you
I'm really pleased with the new wheels, really changes how it looks 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
12th Dec 2022 5:55pm |
There are only 2 faults on a Td5 that will put the MIL on. Throttle pedal (or its associated wiring) or Crank position sensor (or its wiring). If the throttle pedal didn't sort it then it could be a crank sensor fault, likely loom related as they're know to degrade with time 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
12th Dec 2022 10:28pm |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 4947 |
Only thing is, it wont pick up after 30 mph, gets very flat, and starts running very rough. Crank sensors i have seen fail on my dads jeep, those just cut out the car. But i wont rule it out if those can cause trouble. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
12th Dec 2022 11:08pm |
Thanks Stephan 2002 90 Td5 Station Wagon
13th Dec 2022 7:50am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Have you checked the fuel pressure regulator on the side of the block and the PCV valve next to the turbo? changing both made a massive difference to the flat spots on my TD5 |
13th Dec 2022 10:24am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10530 |
I'm trying to catch up on my " offline " time and i have caught up on your thread and finally seen the RR and the 90 with there ribbons on, both looking great.
Congrats to you both 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
24th May 2023 8:37pm |
Thank you Clayton! It's great to see you back 2002 90 Td5 Station Wagon
30th May 2023 8:55pm |
Thank you George, it's good to be back 1996 Golf Blue 300Tdi 110 Pick up. Keeper.
Clayton. |
31st May 2023 9:33pm |
Where did you get those wheel bolt covers? l like those for mine. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
6th Aug 2023 1:35am |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 672 |
Have a look at Charlesworth Mouldings, they produce wheel nut covers 😉
6th Aug 2023 2:29am |
