Home > Maintenance & Modifications > Anyone fitted air suspension to a Defender?
Page 1 of 4 1234>
blackrock
United Kingdom 2012 Defender 110 Puma 2.2 SW Firenze Red
I'm looking at fitting air suspension to a 110 Defender and wondered if anyone else has done this? The reason for fitting is so that the vehicle can go under 2.0m-ish height restrictions.
I've tried searching the forum but not found much.
I have found some kits but wanted to see if anyone had used them as I was about to 'press the button' on a kit when I saw some worrying reviews of the company. The attraction was that they sold a range of parts and controllers etc, so repair later on when the bags wear out or something breaks would be easier.
I'm now thinking more along the lines of a kit from a reputable source, but not sure which one now.
Andrew
Post #958533 16th Jul 2022 5:46pm
markb110
This might help
Post #958542 16th Jul 2022 6:40pm
Forum member, Dowks, has air suspension on his 130:
https://www.defender2.net/forum/post936735...ion#936735 Darren
Post #958551 16th Jul 2022 8:04pm
Sulisuli
Ian Baughn at IRB developments is your man. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #958552 16th Jul 2022 8:14pm
Not_Given
United Kingdom 2011 Defender 110 Puma 2.4 SW Orkney Grey
VB Air 4C on my 110. Gets me down to 2.0m with a cage and Hannibal rack. Well worth it in my opinion.
NG
Post #958567 17th Jul 2022 2:48am
blackrock
Thank you for the information. I have watched those videos and they are interesting, unfortunately those guys are in Australia and shipping to or from there is painfully expensive. The bit they use ar eprobably available here from someone.
I'm now heading towards the VB Air system, I don't think it comes as a kit so I'm hunting for someone to fit it. Top of my list is IRB.
Andrew
Post #958580 17th Jul 2022 8:42am
blackrock
NG
Interesting. That means the VB Air system will work for me, height wise. Can I ask if it was a kit that you fitted, or was fitted somewhere?
Andrew
Post #958581 17th Jul 2022 8:43am
blackrock
As a mad idea I was wondering if I could build some electric spring compressors that compress all four springs on command. All I'm after is a temporary lowering of the vehicle, I'm not after the smoother ride that is advertised (a lot). Presumably the bumps stops are reachable with a compressor, as they must be reached at times. I'm not sure it would bother the springs too much, maybe they wouldn't like being compressed repeatedly, and the mechanics would be interesting to say the least.
Andrew
Post #958582 17th Jul 2022 8:52am
Not_Given
Mine was fitted by a ‘Reassuringly Expensive’ company in North Yorkshire beginning with a T.
VB have authorised fitters across the U.K. I think I ended up contacting them via their website and the sent me details of the nearest installer. It’s not a job I would have wanted to do on my own.
There may be warranty concerns if it’s not via an authorised installer.
Post #958583 17th Jul 2022 8:52am
Force64
United Kingdom 2005 Defender 90 Td5 SW Tonga Green
Look at juice motors videos on youtube. They have done a few.
They are based on borders of Sussex/Kent.
Andy Defender Td5 XS90
Post #958584 17th Jul 2022 9:00am
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
+1 for Juice Motors, I'm planning on using them myself.
They use On Air kit I think.
Same reason for fitting for me... I have a poptop and want to lower the truck for access and also the self levelling feature will help make sure the bed in the roof is level if parked on uneven ground.
Post #958586 17th Jul 2022 9:14am
jimbo55
I’ve got the VB kit on my defender and it’s great, got all the required approvals, as good a ride as you’ll get in a defender in my opinion. I had it fitted to get my defender into a low garage and have never looked back
As part of the approval requirement, the VB kit has to be installed by an approved installer
The “on air” kit for a defender is just a copy of the VB but without any approvals and is basically the same price so seemed a bit of a no brainier to me
Post #958630 17th Jul 2022 4:09pm
blackrock
I'm not sure what you mean by approvals. Are there some regulations that need to be met for MOT or something?
I've no idea what the On Air setup is, really, as their website doesn't work at the moment.
Andrew
Post #958631 17th Jul 2022 4:21pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
Here's a link to the Britpart Kit.
It looks pretty good to me with pre-set ride heights and everything included. It's also about a £1000 less than similar kits.
https://www.lrparts.net/da9110-land-rover-...0-130.html
Available from all Britpart suppliers 2011 130 Utility Body
2005 110 Van
Post #958640 17th Jul 2022 6:31pm
mwestcrew
I guess that one of the important things to consider when choosing a system is if all the parts are available separately for future maintenance.
Also suitable shock absorbers with adequate travel. 2011 130 Utility Body
2005 110 Van
Post #958642 17th Jul 2022 6:33pm
Page 1 of 4 1234>
