Home > Maintenance & Modifications > TD5 rear springs - which brand? |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 537 |
I am planing to go with Alive comfort spring with Fox 2.0 dampers for my mainly road use.
I have heard nothing but good reports on this set up. Just waiting for my piggy bank to fill back up. |
25th Feb 2022 5:46pm |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4406 |
I suspect that the springs are absolutely fine, but the mismatched bushes and Britpart shocks will not be helping at all.
Did the PO replace the bushes with Britpart polybushes? The Britpart Yellow bushes are like hockey pucks, hard and un-yielding. Are the shocks the Britpart Celluar variety? They are awful IMO create such a hard ride. Are the springs black with dashes of colour on them or painted yellow? If dashes, what are the colour combinations. Check out http://www.red90.ca/rovers/springinfo.html to decipher the dashes of colour to spring rates and lengths. What are you planning for the Defender? Work horse or mile-muncher? If the latter or you are planning on towing then perhaps the Alive comfort setup wouldn't be the best option. Whatever you decide spring and shock-wise I would strongly recommend a full set of SuperPro bushes to be starting with. Just about the best bush for all situations. |
25th Feb 2022 6:02pm |
seventh-heaven Member Since: 20 Oct 2021 Location: Norwich Posts: 9 |
Thanks - daily use as yard our yard hack - will be rare to carry heavy loads, will not do massive miles but will occasionally be used for towing boats.
No markings on the dampers, but they are black and the invoice lists them as a Britpart component. In terms of the springs they are all yellow. No evidence of poly type bushes - just rubber so again I suspect that it was plain bog standard Britpart cheapies. |
25th Feb 2022 6:21pm |
If the springs are yellow then they are definitely Britpart and they are OK. The HD Britpart springs are very hard when you have an empty load space.
Personally if I were you I would source a set of TD5 standard springs (these come in single and dual rated versions), SuperPro bushes and some quality shocks. I am a fan of Old Man Emu shocks, but there are plenty of others out there, Fox seem to be the manufacturer of choice at the moment, but Bilstein and Koni are equally good. You do not say whether it is a 90, 110 or 130. I suspect you are not going to want a lift. |
25th Feb 2022 6:41pm |
Sorry! Yes it is a 90 - edited origonal post!!
Yes I had already concluded that the best next step was standard springs - my question was about what Brand? Specifically I suggested: Britpart through to Land Rover appears to vary between about £20 and £100 - and at £100 per spring you are into ALIVE Tuning Comfort Springs territory! So can anyone recommend some standard dual rate springs - as in Brand! |
25th Feb 2022 7:00pm |
