Home > Technical > Rubber or Leather Rear diff seal?
Rabbitwabbit
United Kingdom 1997 Defender 110 300 Tdi CSW Stornoway Grey
Hi all - quick question...which do you prefer - the rubber or leather rear diff pinion seal? My 1997 defender 110 currently has what looks like a reasonably new rubber seal fitted, but it's already leaking having had a reasonably easy life! does anyone have experience of both types of seal? Which would you recommend and why?
Post #923032 27th Sep 2021 4:18pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I used a leather seal in the series one front hub. Worked quite well! I didn't know that there was one for the diff pin oil seals as well?! 1953 80"
1987 mini city e
2011 90"
Post #923098 27th Sep 2021 9:18pm
Rabbitwabbit
Hi Mr James - I didn't know they made the leather seals for the diffs either until yesterday when I stumbled across one. Part number AEU2515G. Most sites seem to stock them, but Craddocks displays and describes the part very well.
Post #923149 28th Sep 2021 8:44am
jst
How many miles?
Sounds more like worn input shaft if new seal not doing its job. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #923280 28th Sep 2021 9:37pm
Rabbitwabbit
Hi. Total vehicle mileage is 68K - so not high for a 1997 vehicle. Without pulling it apart I can't see the overall condition of the shaft, but I wouldn't have expected massive wear on the component at this mileage.
Post #923406 29th Sep 2021 2:03pm
Dinnu
Or seal fitted wrong way? Or breather blocked? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #923415 29th Sep 2021 3:01pm
Rabbitwabbit
Seal is correctly fitted and breathers are fine. I'm thinking that if the vehicle has been stood for a while, then the shaft could have rusted or pitted slightly or the rubber could have become hard due to lack of use - then, as I've started using it regularly then it's started leaking. I'll pull it to bits, give the shaft a clean up and replace the seal and see how it goes. if it still leaks, then I'll look to replace the shaft.
Post #923436 29th Sep 2021 5:05pm
Rabbitwabbit
Eventually I replaced it with a rubber seal and so far it seems to have done the job.
Post #926510 20th Oct 2021 3:57pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Have had a leaky rear diff pinion on my 110 since I got it in 2015 despite a few attempts to remedy it with various rubber and leather seals and giving the flanges a serious clean up. Replaced the flange with a new one and fitted a leather seal around 6-12 months ago which appeared to finally fix it, but noticed in the last few weeks that the diff nose is looking 'damp' again, maybe not the permanent fix I was hoping for.....
Before anyone suggests it the breather is clear with a new pipe ran from the cleaned axle banjo fitting inside the body to gutter level.
Post #926579 20th Oct 2021 9:34pm
Rabbitwabbit
Hi - thanks for your response. I've been working my way around the various bits of leaks etc., and I finally feel like I'm getting somewhere (just the 1 'serious' leak from the transfer box idler shaft!). Once I've finished, then I'll probably need to start all over again - keeping the leaks at bay is like painting the Forth Bridge!
Post #926666 21st Oct 2021 2:01pm
Timo K
Finland
Had a leather type seal in mine, local specialist recommended replacing with a newer rubber type seal, so they fitted the newer type flange and rubber seal, been happy with it so far.
Post #927566 28th Oct 2021 2:14pm
