Home > Technical > Rubber or Leather Rear diff seal? |
Rabbitwabbit Member Since: 31 Mar 2021 Location: Blackpool Posts: 38 |
Hi all - quick question...which do you prefer - the rubber or leather rear diff pinion seal? My 1997 defender 110 currently has what looks like a reasonably new rubber seal fitted, but it's already leaking having had a reasonably easy life! does anyone have experience of both types of seal? Which would you recommend and why?
27th Sep 2021 4:18pm |
Hi Mr James - I didn't know they made the leather seals for the diffs either until yesterday when I stumbled across one. Part number AEU2515G. Most sites seem to stock them, but Craddocks displays and describes the part very well.
28th Sep 2021 8:44am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7742 |
How many miles?
Sounds more like worn input shaft if new seal not doing its job. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
28th Sep 2021 9:37pm |
Hi. Total vehicle mileage is 68K - so not high for a 1997 vehicle. Without pulling it apart I can't see the overall condition of the shaft, but I wouldn't have expected massive wear on the component at this mileage.
29th Sep 2021 2:03pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3234 |
Or seal fitted wrong way? Or breather blocked? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
29th Sep 2021 3:01pm |
Seal is correctly fitted and breathers are fine. I'm thinking that if the vehicle has been stood for a while, then the shaft could have rusted or pitted slightly or the rubber could have become hard due to lack of use - then, as I've started using it regularly then it's started leaking. I'll pull it to bits, give the shaft a clean up and replace the seal and see how it goes. if it still leaks, then I'll look to replace the shaft.
29th Sep 2021 5:05pm |
Eventually I replaced it with a rubber seal and so far it seems to have done the job.
20th Oct 2021 3:57pm |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 777 |
Have had a leaky rear diff pinion on my 110 since I got it in 2015 despite a few attempts to remedy it with various rubber and leather seals and giving the flanges a serious clean up. Replaced the flange with a new one and fitted a leather seal around 6-12 months ago which appeared to finally fix it, but noticed in the last few weeks that the diff nose is looking 'damp' again, maybe not the permanent fix I was hoping for.....
Before anyone suggests it the breather is clear with a new pipe ran from the cleaned axle banjo fitting inside the body to gutter level. |
20th Oct 2021 9:34pm |
Hi - thanks for your response. I've been working my way around the various bits of leaks etc., and I finally feel like I'm getting somewhere (just the 1 'serious' leak from the transfer box idler shaft!). Once I've finished, then I'll probably need to start all over again - keeping the leaks at bay is like painting the Forth Bridge!
21st Oct 2021 2:01pm |
Timo K Member Since: 23 Aug 2012 Location: Helsinki Posts: 169 |
Had a leather type seal in mine, local specialist recommended replacing with a newer rubber type seal, so they fitted the newer type flange and rubber seal, been happy with it so far.
28th Oct 2021 2:14pm |
