Home > My Defender > 110 Puma to M57 and 8 speed auto
Page 3 of 9 <123456789>
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I do like the info on that read out can yours do that mata? 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #924835 7th Oct 2021 12:18pm
AJC
Fantastic.
Post #924837 7th Oct 2021 12:41pm
mata
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
If I added an oil pressure sensor and ambient air temperature sensor (or went with intake air temperature as a fudge) yes I could display the readings/ they’re not measured currently.
Post #924847 7th Oct 2021 1:52pm
Jefinabox
Thanks for sharing, I'm about to start a 35d conversion on mine and it's really nice to see the sort of performance to expect. Looks a top notch conversion.
I'm starting with a 6hp and may go 8hp in a while. Have you any performance stats at all?
Post #924896 7th Oct 2021 8:34pm
H3nry
I’m hunting for engine and gearbox set now, looking for the later M57 with 235hp with 6hp28x gearbox.
@Mar, Is this the same engine you have running in your defender now?
@Jefinabox, mind sharing where you got the engine and gearbox from?
Post #924933 7th Oct 2021 11:30pm
Jefinabox
I got a really cheap donor car from eBay, there's a Facebook group called something like "BMW conversions for land rovers" and there was a chap selling engines and boxes on there
Post #924937 8th Oct 2021 4:16am
Smyles_
Denmark 2008 Defender 130 Puma 2.4 HCPU Cairns Blue
I'm curious to know as to what system you're using to change into hi/lo and diff lock.
Only as this is my lump that arrived today to do the job for my conversion.
 Stuart
Cummins 130 Build Thread
Instagram
04 110 Double Cab - Black (gone)
58 130 Double Cab HCPU - Cairns Blue
Post #925022 8th Oct 2021 6:55pm
mata
Hi Stuart, yes same kit from John, I took it a step further with the solenoids and switch gear though.
Post #925027 8th Oct 2021 7:49pm
mata
No I’ve not measured performance, I just have the dyno measurements. At the moment it feels like there’s twice the engine the car can take when driven hard, it needs brakes and suspension. But that’s forgetting it’s not been built to be high performance, I wanted something more useable and drivable, which I think I is.
Post #925030 8th Oct 2021 7:57pm
Smyles_
Awesome, looking forward to getting it installed Thumbs Up
Think I will stick with the solenoids John provided as I feel the mechanical-human interface fits better with the character of my build, otherwise yes, I too probably would have gone with the carling switches Cool
Now I just need to find a good looking switch cover for it to prevent accidental pressing.... Stuart
Instagram
Post #925034 8th Oct 2021 8:29pm
mata
I think you can set them up so pushed in is ‘normal’, IE high range no diff lock. I also saw someone did something really cool With yellow and red knobs, I think intended for draws but they looked great like an old series..
Post #925036 8th Oct 2021 8:44pm
pj2106
Is this air or electronic actuated? Where do you get it from? 2008 110 2.4 XS Utility (Hagrid)
Post #925040 8th Oct 2021 9:19pm
Smyles_
Chap from the Cummins Facebook group is how I know John.
They're both the same, the only difference is how the solenoids are actuated.
Mines push, but they can be electronically controlled. Bit like a relay except instead of high current output you have high pressure air Laughing Stuart
Instagram
Post #925043 8th Oct 2021 10:34pm
Stiff1
HiLo
Hi, excuse my ignorance but very interested in this.
I get how the switch system is working in the OP install and the advantages there but what is the alternative changing method alluded to above as if you still have a stick, what is the point?
Also what is the cost of this kit or install with the switches?
Where you not tempted with the electronic park break as well to free up room in the footwell?
Thanks in advance.
Post #925065 9th Oct 2021 11:01am
Smyles_
Cost is typically a little over 300 although I got mine on "sale" from John.
You won't need to have a stick if you do this mod. I'm also doing an engine conversion and it's useful to not have to make custom linkages and is less work for the tunnel as at least in my case, the transfer box is an inch or 2 further back and it's mated to a non lr gearbox.
So instead of an electronic switch to the solenoid I just have a mechanical plunger on the valve.
Happy to send John a message if you're interested in one. Stuart
Instagram
Post #925127 9th Oct 2021 8:38pm
