Home > Maintenance & Modifications > Rear ARB kit
dioliahary
Rear ARB kit
Defender 90 with a 200tdi Disco transplant. When looking at fitting a rear ARB kit the rear exhaust gets in the way. Has any encountered this and if so what did you do to work around it please. 1990 200tdi conversion 90
Post #852006 25th Aug 2020 9:07pm
landy andy
Not sure which bit it hitting as it’s not something I’ve encountered. But you can space your ARB down at the mounting points using tow bar spacers as they are the correct hole spacing.
Post #852031 25th Aug 2020 11:09pm
landy andy
Post #852032 25th Aug 2020 11:10pm
dioliahary
Thanks I will have a nosey and try and load a good picture to demonstrate. Will look into the spacer idea. 1990 200tdi conversion 90
Post #852083 26th Aug 2020 9:49am
Mo Murphy
United Kingdom 1984 Defender 90 200 Tdi HT Pennine Grey
Is the exhaust standard Harry ? Or cobbled together with bits of others ?
Post #852088 26th Aug 2020 10:07am
dioliahary
I think the mid to read section is standard, only modified at the engine outlet down pipe. 1990 200tdi conversion 90
Post #852109 26th Aug 2020 11:14am
dioliahary
I think this is it. 1990 200tdi conversion 90
Post #852110 26th Aug 2020 11:15am
Oldowner
You are trying to fit an ARB onto a chassis / exhaust combination that was never designed to accept an ARB, that’s why it fouls.
Post #852126 26th Aug 2020 12:44pm
dioliahary
Ta, I follow a 89 Defender chippy on Insta. I noticed he has a rear ARB fitted hence my curiosity resurrection. Ah well one less job to do the. 👍. 1990 200tdi conversion 90
Post #852127 26th Aug 2020 12:54pm
