Home > Maintenance & Modifications > Fuel filler fixings help please - 300tdi |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2557 |
I think they’re actually a BA thread for some reason, mine were anyway. I replaced with M5 or M6 panhead screws if I recall correctly.
12th May 2020 7:27pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1784 |
You could be correct looking at this, https://www.ebay.co.uk/itm/Fuel-Filler-Nec...Sw9~xeuTrU but I'm not a purist so might try to save a few quid and find something a bit cheaper
13th May 2020 7:40am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2089 |
So that'll be 2BA then if M5 sized.
Mo The Land Rover 90 - Many are called, few are chosen. |
13th May 2020 10:22am |
Lwb97 Member Since: 10 Sep 2015 Location: Powys Posts: 75 |
I’ve only ever seen pozi screws on 300tdi’s. I replace them with m5x20 pozi screws which are readily available and even stainless if you want.
13th May 2020 1:12pm |
Great thanks, I ordered these this morning so hope all will be well
13th May 2020 1:19pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6489 |
The originals are 2BA slotted head 77941, with nuts RTC608.
2BA is 4.70mm major diameter, so as above can be replaced with your choice of M5. Wouldn't recommended stainless without isolating from the panel. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
13th May 2020 1:21pm |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
Just replaced the same on the red zepplin a quick tip put anti seize on the back of the new ones will pay dividends if you need to remove in the future WHAT COULD POSSIBLY GO WRONG
My sky lantern petition http://chng.it/HJXmZC47 |
13th May 2020 1:42pm |
