Home > Maintenance & Modifications > Rear door striker |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 219 |
Hi Sgreenham,
Are you sure you haven’t over adjusted the striker part, ie to far in, meaning the latch can’t actually click fully back on its second click, hope you understand what I’m saying. I did exactly this on my last Puma, and it wouldn’t shut properly, I moved the striker out a bit, and got it to work. Also have you checked that the lock does actually lock properly on its second click. You can check this using a screwdriver to act as the striker with the door open, and see if it holds. Cheers And hope you sort it, Ashbyandy |
7th May 2020 3:56pm |
sgreenham Member Since: 27 Apr 2019 Location: Southampton Posts: 145 |
Yeah the lock works, I’ve removed the striker and tried it in the lock free hand and it works. I’ve tried every possible adjustment for the striker and I just can’t seem to get it to latch. What’s annoying is that I just can’t see what is restricting it. Really frustrating
7th May 2020 4:09pm |
Badger110 Member Since: 06 Feb 2018 Location: South hams Posts: 1036 |
I’ve found the rear door seal to be a culprit in stopping the door from latching correctly.
Once the metal within the seal gets bent it’s a slippery slope to it becoming a right PITA. See how the seal sits from the inside once your door is shut |
7th May 2020 4:24pm |
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 |
Looks like the rubber bumper stop is missing on yours? This helps to wedge the door closed. I don’t think they’re available on their own but the Rear door lock striker is LR067267 £37.10
See in this pic; 2014 Keswick Utility 2.2 |
7th May 2020 5:01pm |
Cheers everyone, I had removed the rubber stop just whilst I was trying to get it to catch. Well I managed to solve the problem. The new door lock I had installed was slightly different to the old one. There is an extra piece of metal in the new one stopping the striker fully seating in the lock. This is the old one...
Click image to enlarge And this is the new one... Click image to enlarge I fixed it by taking a bit off the stricker to allow it to move fully into the lock. Thank god that’s sorted! |
7th May 2020 5:45pm |
