Home > Td5 > Steering Wheel Correct Spline Count |
ijefferyes Member Since: 11 Apr 2020 Location: Radstock Posts: 35 |
Can someone confirm if a 2002 TD5 Station Wagon has a steering wheel with 36 splines?
In addition anyone know where I can get a new one and not for silly money? |
4th May 2020 10:22pm |
Thanks for the confirmation that the spline count is correct. If anyone had a spare steering wheel in a good condition I would be really interested.
4th May 2020 10:35pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 903 |
You aught to be careful and just count the splines. LR used what ever was in the parts bin. Just takw the nut off and count them to be safe. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
5th May 2020 2:36am |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 721 |
As above, the safe way is to count them.
This link may help: http://www.web-rover.co.uk/articles-steeringwheels.html |
5th May 2020 9:53am |
Great, thanks for the advice. I will take the wheel off and have a look.
5th May 2020 10:08am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2290 |
Hello ijefferyes
Should be 36 but as advised wheel off and count, I know two owners that have different than the charts tell you, both wanted a new steering wheel fitted with a quick release boss (of which i'm a big fan) so to be sure count them up... Good Luck SKIP https://www.defender2.net/forum/topic83242.html |
5th May 2020 10:20am |
Notyalc Member Since: 27 Jul 2018 Location: Northumberland Posts: 144 |
You don’t need to take the wheel off, just the nut and washer. There is a large difference in the number, so just go round with a pointer, if you are 1 or 2 out it won’t matter if that makes sense. |
5th May 2020 8:41pm |
isacs Member Since: 28 Aug 2015 Location: Leamington spa Posts: 404 |
I have a spare. I’ll dig it out tomorrow. Had only covered 40k before I took it off so should be reasonable
5th May 2020 10:28pm |
@isacs if you can pm me how much you want for it and maybe some pictures once you have dug it out, that would be great!
6th May 2020 8:02am |
Right, took nut off and counted the splines and it is definitely a 36 spline wheel.
So, now just to find a replacement! |
10th May 2020 11:29am |
